Thread Number: 62812
1960 Westinghouse Dryer Test-Run |
Post# 853774   11/26/2015 at 16:30 (3,066 days old) by moparwash (Pittsburgh,PA )   |   | |
Finally after getting the timer and selector back in...a test run of it!
I still am not able to find out where the other wire for the timer goes on and if I installed the rotating drum that indicates which of the 8 cycles you are on..(though heat comes out of the Auto-Dry)selection. So far it heats up and dries clothes, but without the timer I have to check the clothes manually. At least it lights up all nice |
Post# 854090 , Reply# 1   11/28/2015 at 20:48 (3,064 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 854096 , Reply# 2   11/28/2015 at 21:07 (3,064 days old) by Northwesty (Renton, WA)   |   | |
So the timer doesn't advance? |
Post# 854101 , Reply# 3   11/28/2015 at 21:23 (3,064 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 854108 , Reply# 4   11/28/2015 at 21:49 (3,064 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 854137 , Reply# 5   11/29/2015 at 06:40 (3,064 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 854139 , Reply# 6   11/29/2015 at 07:36 (3,064 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 854174 , Reply# 7   11/29/2015 at 11:28 (3,064 days old) by jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Here are 2 wiring diagrams for the DBA-30 dryer. The pictorial shows wire connections and routing, the schematic is for tracing current flow. Hope this helps with your dryer problem.
Post# 854200 , Reply# 8   11/29/2015 at 13:36 (3,064 days old) by moparwash (Pittsburgh,PA )   |   | |
Thanks..to Jeff and Steved for the diagrams..while the timer still does not advance its now hooked up right....is there a way to bench test a timer motor ?
This post was last edited 11/29/2015 at 18:53 |
