Thread Number: 62855
Help with Lady Kenmore 1970 900 Series Piano Key |
Post# 854100 , Reply# 1   11/28/2015 at 21:20 (3,064 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 854105 , Reply# 2   11/28/2015 at 21:37 (3,064 days old) by eronie (Flushing Michigan)   |   | |
Sounds to me the snuber is not in place. |
Post# 854154 , Reply# 3   11/29/2015 at 08:46 (3,063 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 854262 , Reply# 4   11/29/2015 at 21:32 (3,063 days old) by floyde (Los Angeles, CA)   |   | |
NowI notice that the agitator moves a little bit as the spin cycle ends. What does this indicate? |
Post# 854316 , Reply# 5   11/30/2015 at 07:42 (3,063 days old) by cleanteamofny ((Monroe, New York)   |   | |
It's normal the agitator will rotate/spin one or two revolutions when the cycle end. Your snubber plate may need to be cleaned as well as the plastic snubber needs to be scruff up on concrete. Please post a video so we can help you! Please excuse the dirty tub ring, washer is in storage. |
Post# 854330 , Reply# 6   11/30/2015 at 10:29 (3,062 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 854340 , Reply# 7   11/30/2015 at 12:06 (3,062 days old) by floyde (Los Angeles, CA)   |   | |
Is it easy to lift the lid up on the Lady? So you just unhook that wishbone looking thing and the little plate is the snubber? |
Post# 854352 , Reply# 8   11/30/2015 at 13:52 (3,062 days old) by DADoES (TX, U.S. of A.)   |   | |
The snubber is the part that fits into the spring. The top is latched by spring clips a couple inches in from each front corner. Slip a putty knife into the seam to depress the clips while lifting the top ... or pulling simultaneously sharply forward and upwards on the top usually will get it open.
Post# 854374 , Reply# 9   11/30/2015 at 16:32 (3,062 days old) by cleanteamofny ((Monroe, New York)   |   | |
Your welcome, Do as Rich recommend but pull the machine 10 inches away from the wall to open the top fully to avoid control panel damage! Pull up on the metal snubber holder with one hand and slightly push the plastic snubber with the other hand. Soapy water may have splashed on this area and became too slippery for the snubber to reduce excessive vibration! |
Post# 854423 , Reply# 10   11/30/2015 at 20:15 (3,062 days old) by delaneymeegan (Midwest)   |   | |
Post# 854430 , Reply# 11   11/30/2015 at 20:31 (3,062 days old) by cleanteamofny ((Monroe, New York)   |   | |
Post# 854747 , Reply# 13   12/2/2015 at 19:09 (3,060 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
