Thread Number: 62871
/ Tag: Classified Ad Finds
FREEE - did anyone try contacting? NIce GE Washer and dryer |
Post# 854182   11/29/2015 at 12:00 (3,068 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 854202 , Reply# 1   11/29/2015 at 13:44 (3,068 days old) by appnut (TX)   |   | |
Post# 854208 , Reply# 2   11/29/2015 at 14:46 (3,068 days old) by delaneymeegan (Midwest)   |   | |
Bob, I would think they use the colors on the timer to coordinate with the push buttons on the left. The push buttons were supposed to reference a particular type of FABRIC. This washer has the toggles, instead of the buttons, which merely designate speeds and temps. The colors on the dial would be relatively meaningless, in this case. I'm guessing you had a more deluxe model with the push-buttons? Although, I've seen the toggles with the 3 speed selector switch: Fast/fast("Normal" wash), fast(wash)/slow (Permanent Press ?), and slow/slow (Delicates). I always thought the middle one should be slow(wash)/fast(spin). That was nearly always the speed selection I chose when using a GE FF. |
Post# 854236 , Reply# 3   11/29/2015 at 19:10 (3,068 days old) by appnut (TX)   |   | |
Delaney, the color coordinated description you gave applied to the dryer. But this washer didn't have coordinated colors in its timer dial and I've seen extremely few like this and this is the first with this high up the line model. Mine had color coordinated timer dial with my dryer. Maybe these weren't purchased together. And actually, only the programmed TOL washer had the color coordinated lettering by the buttons for the appropriate cycle on the timer dial. |
Post# 854238 , Reply# 4   11/29/2015 at 19:22 (3,068 days old) by Yogitunes (New Jersey)   |   | |
Post# 854251 , Reply# 5   11/29/2015 at 20:26 (3,068 days old) by delaneymeegan (Midwest)   |   | |
They aren't a matched set. The graphics don't match. The hoods are different-washer simply has GE in center, dryer has wording on each end. The trim colors around the three sections is different on each one. All the lettering on the washer is white on a black background. On the dryer some letters are colored. Even the typeface and spacing is different. The washer looks like a Kmart special. I'm not sure exactly when Kmart stopped selling major appliances in the early 80s, but I do remember going to Kmart around '82, or so, and seeing a model very similar to this washer and loving the toggles. |
Post# 854268 , Reply# 6   11/29/2015 at 22:04 (3,068 days old) by pulltostart (Mobile, AL)   |   | |
Here's another of the same genre; no colors. The cabinet has had a rough life. $70.
Lawrenceville, GA
Post# 854308 , Reply# 7   11/30/2015 at 04:51 (3,067 days old) by appnut (TX)   |   | |
