Thread Number: 62983
My new Maytag A407 |
Post# 855417   12/6/2015 at 20:00 (3,035 days old) by robbinsandmyers (Conn)   |   | |
Just picked up an A407 ser# 459759UB from a friend and cleaned her all up and washed my first load and love it. How do I find the year it was made? I know right off the bat its going to need belts they look original and stretched. The slides on the motor are kinda sticky and will need cleaning. I was surprised the trans didnt have a fill plug to top off any oil. The pilot light also flickers when the machine is on so that will need replacing and I noticed after the machine came to the end of the cycle and shut off the light didnt go off either until I pushed the timer knob in. Is this normal? Other than that it runs great and was worth the $50.00 plus free help getting it home.I hope I get some years out of it unless an older model with back lit panel in better shape comes along first. :)
Post# 855418 , Reply# 1   12/6/2015 at 20:09 (3,035 days old) by FEster (Lafayette La USA)   |   | |
I dig those center dial Maytags. My faves have the one with the back lit glass, but the blue/green and gold backs are a close second. |
Post# 855419 , Reply# 2   12/6/2015 at 20:11 (3,035 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 855425 , Reply# 3   12/6/2015 at 20:45 (3,035 days old) by robbinsandmyers (Conn)   |   | |
Post# 855428 , Reply# 4   12/6/2015 at 20:59 (3,035 days old) by scoots (Chattanooga TN)   |   | |
Somebody will be along to look up the build date from your serial number, but I'd guess you have a late 60s model. You'll notice that half the dial is taken up by a timed soak? This was for the enzyme pre-soak detergents that were popular at the time but the cycle is now pretty much obsolete.
You'll also notice a button for "Permanent Press"? The permanent press fabrics of the time required elaborate water changes in the rinse cycle to cool the fabrics down correctly so that they didn't take wrinkles. Fabrics are now no longer made this way, so this feature is also obsolete and would be a real water-waster. Hold off on replacing the belts, they may be old but Maytags MUST have Maytag specific belts that are much slacker than you'd expect (the motor deliberately "slips" at some points in the cycle.) They are super-easy to replace, perhaps take a few pictures for expert opinions on condition. One belt runs the agitator and this is the unit that typically needs replacement. The other just runs the pump, and these are rarely in need of a change out. Maytag gear boxes typically don't have an oil fill plug: The transmission is intended to be a permanently sealed unit and the grease is replaced at the time of a pull out and rebuild. Nice looking machine. Have fun with it. |
Post# 855429 , Reply# 5   12/6/2015 at 21:00 (3,035 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 855430 , Reply# 6   12/6/2015 at 21:01 (3,035 days old) by scoots (Chattanooga TN)   |   | |
Post# 855446 , Reply# 7   12/6/2015 at 22:18 (3,035 days old) by 70series ( Connecticut.)   |   | |
The pilot light will definitely work. A neighbor who lived across the street from me had this model with the matching dryer. I believe this is an early 70s build. |
Post# 855456 , Reply# 8   12/7/2015 at 00:08 (3,035 days old) by robbinsandmyers (Conn)   |   | |
re:belts. They look really worn and stretched esp the pump belt. In fact the pump has been adjusted to its farthest point to take up as much slack as possible and the machine does make some chattering when it goes into wash mode for a few seconds that could be similar to noises refered to as bad belts in a post I read on here. The lamp does flicker which I cant see how its possible seeing as how its a neon bulb like those cheap 120v outlet testers have only it has a resistor on it in the socket. Its a pet peeve and wont make the machine run better but Im the kinda guy if something was made to work a certain way and it doesnt anymore than I replace it. Not sure if Im going to find this part unless its from a junk machine.
Post# 855459 , Reply# 9   12/7/2015 at 00:33 (3,034 days old) by rp2813 (Sannazay)   |   | |
If it's just a small neon lamp, you can likely replace only the lamp and not the whole assembly. I've done this with indicator lamps for old coffee makers and on vintage lighted dial GE clocks. Snip or un-solder the bad lamp and solder the new one on.
I'm sure someone here will be able to advise on the specific lamp number you will need, such as an A-2-B or something like that. It would look something like this:
Post# 855463 , Reply# 10   12/7/2015 at 01:25 (3,034 days old) by DADoES (TX, U.S. of A.)   |   | |
The pump belt normally is quite loose ... almost alarmingly so. Correct adjustment is by pinching the pump belt together halfway between the pulleys. There should be 1/4" space when the motor carriage begins to move against the spring tension. More than 1/4" indicates the pump is adjusted too tight. |
Post# 855621 , Reply# 12   12/8/2015 at 00:17 (3,033 days old) by hippiedoll ( arizona )   |   | |
Post# 855624 , Reply# 13   12/8/2015 at 00:53 (3,033 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 855642 , Reply# 14   12/8/2015 at 03:12 (3,033 days old) by appnut (TX)   |   | |
Post# 855730 , Reply# 16   12/8/2015 at 18:54 (3,033 days old) by ken-n-nancy (Bedford, NH)   |   | |
There's also a DE606 for sale in Manchester, CT. CLICK HERE TO GO TO ken-n-nancy's LINK on Hartford Craigslist |
Post# 856019 , Reply# 17   12/10/2015 at 14:45 (3,031 days old) by robbinsandmyers (Conn)   |   | |
Many thanks for the replies. The driers look tempting but alas I have the landlords drier to use and space is scarce. I ordered a pair of FSP belts online and will install them in the next day or so. It really needs them as the agitator barely works with a large load and it doesnt spin as fast as it should plus I can hear the belt chirping its slipping so bad. Prob original belts. The neon bulb has a resistor on it, Im wondering why? I thought of getting just a plain bulb but they must have installed that for a reason. Also, my motor has red wheels and not square slides. Whats the best way to clean the muck from the tracks and should I lube the rollers or leave it dry? I was thinking Zoom Spout on the wheel axles. So far I love this thing its really made well. Thanks again.
Post# 856375 , Reply# 18   12/12/2015 at 23:19 (3,029 days old) by robbinsandmyers (Conn)   |   | |
I installed the new belts and even hit the rollers with some Zoom Spout but I still get a belt noise so I think maybe the slides need a good cleaning and greasing. The tub still takes too long to come up to speed and pretty much drops to its knees when the rinse cycle is happening its slipping so bad. Almost comes to a stop. Im deff gonna order new motor springs also as I think these lost some tension. Minor set backs but hopefully it will be working as its supposed to in short order. Any suggestions?
Post# 856409 , Reply# 20   12/13/2015 at 09:30 (3,028 days old) by robbinsandmyers (Conn)   |   | |
Yes during the rinse/spin cycle it practically comes to a stop from the clothes being weighted from the water from a long rinse period while spinning but it seems to come up to normal spin speed slower than videos Ive seen of these. The belts I replaced really werent bad but prob stretched as Ive found out they were originals. Ive saved them for spares. I also dont seem to notice a difference in agitator speeds when I switch from normal to gentle etc while its working. Im kinda leaning towards the slides needing cleaning/lubing and new motor springs as a fix but I could be wrong. Im gonna try and figure out how to post a video of it running and making that noise. Many thanks for the help.
Post# 856413 , Reply# 21   12/13/2015 at 09:51 (3,028 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Are you sure that the pump belt is VERY loose if it is anything resembling tight the main drive belt will slip too much as the tight pump belt pulls the motor inward slightly and causes the main belt to slip more. If the motor carriage moves freely you do not need new rollers.
Other than these possible problems you probably have a much serious problem as the last poster stated. |
Post# 856418 , Reply# 22   12/13/2015 at 10:40 (3,028 days old) by robbinsandmyers (Conn)   |   | |
Hmm, well Ive tried several times to post a video on the comp and also my phone but it just isnt an option it seems. Is it possible or just pics?
re: pump belt. Yes its quite loose. I saw a video online how to adjust it and followed it precisly. I almost think its too loose as the tub doesnt seem to pump out as fast now. A video would really help me explain it if I was able to upload it. Its weird because when the machine goes into spin it takes right off like its going to spin like hell but looses steam after 30 seconds or so and would eventually come up to speed if the rinse cycle didnt bog it down weight wise with water. This is driving me nuts. |
Post# 856420 , Reply# 23   12/13/2015 at 10:45 (3,028 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 856421 , Reply# 24   12/13/2015 at 10:54 (3,028 days old) by robbinsandmyers (Conn)   |   | |
Post# 856429 , Reply# 25   12/13/2015 at 11:27 (3,028 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 856436 , Reply# 27   12/13/2015 at 12:42 (3,028 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 856437 , Reply# 28   12/13/2015 at 12:44 (3,028 days old) by robbinsandmyers (Conn)   |   | |
The pump itself does spin freely. In fact I took the little screw out on the side and squeezed some Zoom Spout in there but Ive turned it by hand and it spins very easy. I did turn the water valve off once to eliminate the rinse cycle and she spun like a banshee once it was able to get up to speed without the added drag of water being added. I did forget to mention that when the machine first goes into the agitate cycle when first started the agitator moves slowly and the tub seems to want to spin instead of staying stationary then once the agitator comes up to speed the tub just turns in small notches. With the front off it does want to agitate and come up to spin quickly. I moved the motor back when it engaged into spin mode to tension the trans belt and I lt go because I was afraid water was going to splash over and go on the floor because the pump wasnt pumping it out as fast as it was trying to spin. If I could load that video I think that would help. Any ideas on that???
Post# 856446 , Reply# 29   12/13/2015 at 13:35 (3,028 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
A full tub of water (large) should empty in about 90 seconds. |
Post# 856457 , Reply# 31   12/13/2015 at 14:18 (3,028 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 856467 , Reply# 33   12/13/2015 at 15:17 (3,028 days old) by robbinsandmyers (Conn)   |   | |
I wasnt going to let this get the best of me today because Im the type of person that 1- doesnt buy cheap il-designed garbage, and 2- if I own it, its in perfect working order. I went downstairs and ran a large load of water through a full cycle. Pump wasnt really doing much and the drain sound didnt have the authority it should, the machine on the rinse cycle would just barely start to come up to speed when the spin cycle was over and it would have to stop and begin its second fill. I did two empty loads like this and the second was even worse. The tub wouldnt even completly empty at all and the drain sound was barely a trickle. I flipped the machine back and popped the belts off and peeked under and noticed the trans pulley had a film of oil on it from all the years. Not serious but what I call a sweat leak over many years. I was careful to notice the kitchen floor of the house we removed it from all those years because if it left spots on the floor I wasnt going to take it. There were none. So I looked in the pulley sheave and although it looked clean when I ran my fingers through it I did get slippery fingers. I took some LA's Awesome and cleaned all the sheaves and belts off of any oil whatsoever then reasssembled and tried again. A little better but it wasnt pumping the water out like it should. The motor slides were smooth and not binding in any way. My last resort was tipping the machine back again and doing another pump ajustment as it seems insanely loose. I loosened the three screws and slid it to its farthest point. Slightly tightened the one closest to the motor then stuffed the motor back to tighten the trans belt. The pump didnt move at all and the belt still had less than the 1/4" play. Long story short I had to leave the pump at its farthest point to get the adjustment. If I needed any more I wasnt getting it lets just say that. And these are factory FSP belts to boot. Set the machine back on the floor and even levelled it better than it was before because it was 1/2" too far back. Now it works perfect. Im thinking it was a combo of the two but more the pump belt adjustment because it couldnt evacuate the tub fast enough. What an ordeal! But feeling accomplished. I also think the moving tub issue was the slipping trans belt because it doesnt do it now and agitates like it means it along with pumping like Engine 51.
re: workings of a Maytag. Nope. Im a small engine guy that also restores antique powered mowers and old diesel Mercedes. I play with vintage fans, Edisons, Monitor Tops etc but not washers or driers. Thirty years ago when I was a kid I helped the old guy around the corner in his appliance repair biz so went out on calls on these but pretty much forgot it all over the years although its slowly coming back. He was a smart old German and also collected the machines. I remember an Easy copper tub wringer, Locomotive, two tub Westinghouse, L-4-48 Westinghouse, WD something or other Westinghouse, and his mint 1958 Westinghouse W1000 and D1000 set in dark grey. The washer needed an escapement that was discontinued and he found a NOS one a fellow repairman had for $100.00 but was too cheap to buy it. He was a Westinghouse guy for sure and even had metal Westinghouse kitchen cabinets! There still may be some in the basement of his old house. Anyway many thanks for all the replies and advice I really appreciate the help. Lets hope this is the last of it for a while so I can enjoy it. :) |
Post# 856474 , Reply# 35   12/13/2015 at 16:41 (3,028 days old) by robbinsandmyers (Conn)   |   | |
Well I learned a lot from all the advice given and would still be scratching my head had I not already joined here a few weeks prior to finding this machine simply by a chance convo with a friend. I did consider the carb spray at first but the fumes would have had my upstairs neighbor running down in a panic. I get that LA's Awesome at the dollar store and its the best degreaser Ive ever used and if you get any on your hands it doesnt sting. I highly reccomend it. In fact in the next week or so when I get time Im going to remove the front again and wipe clean as much of the bottom and insides of it with some rags after I spray it down. It should clean up nicely. Maybe a new thread with before and after pics. As much as I like this machine Im still saddened of that mint 1962 A101 I had to sell when I moved 10 years ago. It was a cream puff and silent as a whisper when it ran.
Post# 856790 , Reply# 36   12/15/2015 at 20:00 (3,026 days old) by robbinsandmyers (Conn)   |   | |
Well all was going good the past few loads with the washer and all of a sudden its aquired a new glitch. It seems when its halfway through its first spin cycle before it goes into rinse mode the machine simply shuts off. If I push the timer knob in then back out it goes on it merry way through the rest of the wash cycle. I dont even have to turn the timer just a quick one two of the knob does it. Im thinking timer now?? Is this a good time to say yikes!? |
Post# 856867 , Reply# 37   12/16/2015 at 06:50 (3,025 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 856909 , Reply# 38   12/16/2015 at 11:37 (3,025 days old) by tinkr (Phoenix Arizona)   |   | |
Post# 857092 , Reply# 41   12/17/2015 at 12:36 (3,024 days old) by robbinsandmyers (Conn)   |   | |
I found a timer online for $127.00 plus Im getting a motor spring kit also. This should finally take care of this beast but at least I know what I have which is better than todays garbage. Hopefully the timer is a direct fit. Again, I cant thank you guys enough you've all been awesome. I will deff keep you updated on my progress. John.
Post# 857127 , Reply# 42   12/17/2015 at 15:13 (3,024 days old) by Robbinsandmyers (Conn)   |   | |
Post# 857129 , Reply# 43   12/17/2015 at 15:25 (3,024 days old) by LaVidaBoem ()   |   | |
We'll see wht we can do... CLICK HERE TO GO TO LaVidaBoem's LINK on eBay |
Post# 857208 , Reply# 44   12/17/2015 at 23:13 (3,024 days old) by robbinsandmyers (Conn)   |   | |
Post# 857611 , Reply# 45   12/20/2015 at 20:09 (3,021 days old) by robbinsandmyers (Conn)   |   | |
Hi guys. While doing clothes today I noticed when its spinning there was a knocking noise coming from the tub. I took the agitator off and noticed the upper seal is starting to leak a small amount trans fluid. Im not getting any spotting on the clothes though. How hard is this to change and should I replace the bearing also as is has some play? Why am I getting the feeling Im going to end up over hauling this beast?!?
Post# 857754 , Reply# 47   12/21/2015 at 17:50 (3,020 days old) by robbinsandmyers (Conn)   |   | |
I know, you may be spot on with that assesment of price. Right now Im in a holding pattern until the timer and motor slides and springs come in but I plan on removing the motor and spit shining the slide area clean then greasing and reinstalling the motor with new slides and springs plus the timer as the trans belt is still slipping. The tub indexes which means a tired brake assy I guess. Its also still slowing to a crawl on the rinse cycle when its spinning even if I turn the water valve off so it can spin the rinse water from the load it never comes back up to speed just spins about 1/4 as fast as it should. I just put it in spin with a dry tub and I can hear a "hiss " which is telling me the radial tub bearing is tired and should be replaced which isnt hard if I had the spanner to remove the brake unit which I would also replace. The knocking I think may be the spin tube sleeve which again doesnt look hard but I havent the spanners. Another symptom I have is when its on its first wash cycle and I push the button from "Normal" to "delicate" it stops agitating. "Permanent press" makes no change at all, it just seems to agitate at normal speed. Im hoping someone here in CT will chime in that has the spanners I could borrow for a fee because I would replace all that needs replacing and be good for many years with this thing. As it is I cant trust it to run through a complete cycle like it should.
I did take a pic of the top of the trans with the agitator off but for some insane reason when I try to upload them half the pics on my folder dont even show up to down load through the site. Do I have to change the format? I hope this hasnt gotten too long winded but Im trying to give as much info as possible. Maybe if I can remember my youtube password I will try and download a video. Thanks again. John. |
Post# 857762 , Reply# 49   12/21/2015 at 19:01 (3,020 days old) by robbinsandmyers (Conn)   |   | |
Post# 857888 , Reply# 51   12/22/2015 at 15:34 (3,019 days old) by robbinsandmyers (Conn)   |   | |
Post# 858025 , Reply# 53   12/23/2015 at 15:17 (3,018 days old) by robbinsandmyers (Conn)   |   | |
Post# 858063 , Reply# 54   12/23/2015 at 17:55 (3,018 days old) by robbinsandmyers (Conn)   |   | |
Got the timer today and they goofed. Sent me a #204899 for $115.00 so I called and will ship it back for refund, not to mention it was used in an open bag when they stated new. Used your Ebay link and got the #204889 for half that. I will use the saved cash towards a brake unit and radial bearing?!? Many thanks again.
Post# 858170 , Reply# 56   12/24/2015 at 13:11 (3,017 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 858356 , Reply# 57   12/25/2015 at 23:00 (3,016 days old) by robbinsandmyers (Conn)   |   | |
Thanks for the advice on those. Im just wondering on the brake assy as the tub is indexing while the wash is agitating. What would cause that? I wonder if its the tub bushing that could be making noise and not the radial bearing? I have a funny feeling if I cant replace the top transmission seal and bushing that its going to need a trans. It left a brown spot on two towels last load. Im really wishing I didnt buy this and waited for a better one but it was from a trusted friend.
Post# 858357 , Reply# 58   12/25/2015 at 23:33 (3,016 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 858442 , Reply# 59   12/26/2015 at 14:08 (3,015 days old) by robbinsandmyers (Conn)   |   | |
I removed the agitator today and saw what appeared to be a brown encrusted mess. The oil leak didn't look as bad as before and I wiggled the shaft looking for play and didn't notice any at all. Looks like a snap ring and washer to replace the seal so I'm going to try to source a part number online. I did wire brush the corroded locking ring clean. It will need a good soaking in Kroil before trying to remove it. I did rock the tub side to side and there is a definite knock to it. Gonna need that tub bearing I'm thinking its that bad. I may as well change both bearings, bushing and top seal as well as clean and replace motor slides and springs which those will happen Sun then the correct timer when it arrives. All that other stuff along with spanners I'm going to start acquiring then spend a few hours tearing this thing down. Let's see if these pics load this time.
This post was last edited 12/26/2015 at 14:27 |
Post# 858450 , Reply# 61   12/26/2015 at 14:43 (3,015 days old) by robbinsandmyers (Conn)   |   | |
Im going to have to take another peek I didnt notice a locking screw. The pics seemed to load no problem from my tablet. Not sure why they didnt from my comp. When the time comes if I cant remove that ring should I angle the chisel like Im trying to loosen it or straight down from the top to split it? Sun will be to concentrate on the motor area then take some LA's Awesome and wipe the pulleys, belts, and overall general area pained grey in the belly and underneath as clean as possible. This thing will need a good going through for sure and Im going to be sinking more money than I hoped but at least when its done it will be good for many more trouble free years. I still wish I had found a cleaner older unit with lighted panel close by but one will show in time. I cant imagine what they washed in this thing all those years to brown the tub although this was on a farm so who knows.
Post# 858452 , Reply# 62   12/26/2015 at 14:46 (3,015 days old) by LaVidaBoem ()   |   | |
...no use trying to turn it with the chisel...
But be careful, you don't want to hit the porcelain tub, and knock out a chunk.
Good Luck, LaVidaboem
Post# 858593 , Reply# 63   12/27/2015 at 10:41 (3,014 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 858688 , Reply# 64   12/27/2015 at 22:59 (3,014 days old) by robbinsandmyers (Conn)   |   | |
Just downloaded this video and I hope it comes out. I started it at the last few seconds of the first wash cycle through drain/spin to the rinse cycle where it slows down during rinse then tries to recover once rinse has ended only to have to stop spinning as the second wash starts. You can hear a knocking sound and also a sloshing while its slowing down during the rinse phase. The timer also did its thing while spinning also but I nudged it to keep it running. I removed the motor and cleaned both metal brakets with a wire brush they were pretty rusty. Then I greased the slides and reinstalled it with new springs. The belt was still slipping and agitation was slow even after I cleaned any trace of oil or grease off the pulleys and belts. I even wiped the inside of the machine and bottom. I ended up going with 3 springs on the motor. Hope this helps. Thanks. John.
Post script: Forgot to mention this load had two pairs of jeans, two sweat shirts, 6 tee shirts and 6 pairs of shorts. Not sure if I over did it?? CLICK HERE TO GO TO robbinsandmyers's LINK |
Post# 858933 , Reply# 66   12/29/2015 at 10:22 (3,012 days old) by robbinsandmyers (Conn)   |   | |
Hmm you've got me thinking on that now. I'll have to remove the top sometime this week and see if somethings floating around in there partially blocking the drain to the pump. The stand pipe is about 4' away from the washer and about 18" higher than the top of the machine. Not sure if that distance and height matters? Doesnt seem to have an issue on the final drain and spin speed but then again it doesnt rinse on that one. One time when it was slowing in the rinse/spin mode I thought the belt was slipping so I pulled back on the motor slightly to put more tension on it. It actually bogged the motor to the point the starting switch was kicking on and off it was loading down that bad so there a deff drag on that tub then when this happens. Even more so when it first goes into spin mode with a full tub of water.
The correct timer came today and I tried to install it but stopped. There was a couple of terminals that didnt have the same numbers as my old timer. Are there a few wires that go to different terminals or dont get used at all? The new timer looks nothing like mine. Mine is a square box where the new timer has a flat profile. I havent sent the incorrect one back yet and looked at both and externally the 204889 and 204899 look the same. Are there online wiring diagrams to show timer replacement? Thanks. |
Post# 858973 , Reply# 68   12/29/2015 at 14:52 (3,012 days old) by mrb627 (Buford, GA)   |   | |
Post# 858992 , Reply# 69   12/29/2015 at 16:49 (3,012 days old) by robbinsandmyers (Conn)   |   | |
La VidaBoem, I can get a bucket at Home Deopt and try that over the weekend on Sun. Problem is most of the basement is part of the tailor shop where I live. Its in front of the house and goes into the basement where its closed off. My landlord is old school Italian and if he hears me tinkering or playing with water he will rock the boat and be a pain so I work on this in cloak of darkeness when he's closed like after 6PM weeknights or Sun/Mon when the shop is closed. I agree it fighting the water.
Malcom, yes its the original drain hose with the machine, Only thing I did was cut the bend off the end and stick a metal sleeve inside and added another foot plus elbow from the landlords dead Whirljunk. The machine is 4' away from the wall where the standpipe is but the hose has a nice graceful flow to it no kinks. I will try and make a video of the machine and pipe location but its an ordeal loading it unless Im screwing it up as usual. Give me a rusty 1929 Locke lawn mower thats been sitting outside 40 years and I can get it running no problem but comp stuff still stumps me after 16 years LOL. Thanks as usual for the help guys. This post was last edited 12/29/2015 at 17:05 |
Post# 860330 , Reply# 70   1/5/2016 at 21:49 (3,005 days old) by robbinsandmyers (Conn)   |   | |
Sorry for the delay. Havent been feeling too well lately plus the holidays. My timer is a 204889. Here is a pic of the machines location to the standpipe. Its about 5' from the wall. I cut the elbow off the original drain hose and spliced the extension you see in the pic. The splice is just out of site at the top of the dryer. Hope this helps. I hope you guys had a great Christmas and New Years. Thanks. John.
Post# 863276 , Reply# 71   1/21/2016 at 11:34 (2,989 days old) by robbinsandmyers (Conn)   |   | |
Just bumping this thread up. Its still doing its thing and its such a hassle now to bbaby sit it when using. I need to replace the timer but the new one doesnt have the same terminals as my old one. Does anyone have a wiring diagram for these? It seems my lifeline has disappeared and I never recieved the diagrams I was told were mailed a month ago and my emails arent getting returned. I tried removing the top cover on the tub to see if a sock was blocking the drain but the inner and outer tub are so close even with a flashlight I couldnt tell. Looks like the inner tub has to come out for that. The machine doesnt seem to spin as fast in the first cycle as it seems to do in its last spin mode. Not sure if this is normal? I also noticed when washing if I press the button from regular to premanent press it stops agitating. Normal to delicate makes no change in agitation speed. Maybe the switch is shot? Thanks for any possible help on this.
Post# 863290 , Reply# 72   1/21/2016 at 12:45 (2,989 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 863405 , Reply# 73   1/21/2016 at 22:38 (2,989 days old) by robbinsandmyers (Conn)   |   | |
Post# 863407 , Reply# 74   1/21/2016 at 22:47 (2,989 days old) by wayupnorth (On a lake between Bangor and Bar Harbor, Maine)   |   | |
Post# 863548 , Reply# 75   1/22/2016 at 18:21 (2,988 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 863811 , Reply# 76   1/24/2016 at 11:25 (2,986 days old) by robbinsandmyers (Conn)   |   | |
Post# 863837 , Reply# 77   1/24/2016 at 14:15 (2,986 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 865496 , Reply# 78   2/4/2016 at 12:40 (2,975 days old) by robbinsandmyers (Conn)   |   | |
Ive not gotten around to the timer swap yet as Ive been busy with this new oil leak staining my clothes. I just purchased off Ebay hopefully all the parts I need to fix the leak and also replace the tub bushing assy ( which I think is causing the knocking sound) and seal kit plus the spanner wrench to do it all. Ive also noticed the water level switch may be going or coming out of adjustment as the large setting only fills up to the bottom of the second hole from the top on the agitator. When I first got it it was the bottom of the top hole which I think was still too low. Here is a link to the auction. I hope this will fit my A407 as I just assumed lol. While I have it all apart Im going to see if I can replace the oil in the trans somehow. By the time Im done this whole machine will be reworked! Ive also figured out my first spin cycle issue of the tub slowwing to a crawl. Firstly it doesnt come up to speed as fast as it should, Im thinking the tub bushing is dry and worn and binding somehow although its final spin is just fine. The other thing is once all the water is spun out of the tub and its trying to come up to speed, all the rinse water never gets pumped out of the tub. Ive proved this when the rinse is just about to shut off and the tub has almost stopped turning its going so slow to the point I reached in and stopped it with the machine running. There is all the rinse water in the bottom of the spin tub dragging it down. Not sure why this is happening. Whether it be the stand pipe is too far/high that a small amount of water is unable to be pumped out of the tub or there is in fact a piece of laundry in the outer tub blocking the drain hole. I removed the top cover and tried looking between the spin and outer tubs but they are too close and I couldnt see anything with a flashlight. I'll know for sure when its torn down. Does this kit look right for my machine? Thanks. CLICK HERE TO GO TO robbinsandmyers's LINK on eBay |
Post# 866045 , Reply# 79   2/7/2016 at 21:57 (2,972 days old) by robbinsandmyers (Conn)   |   | |
I had some free time today and finally swapped out the timer. The new timer wasnt compatible at all. I unplugged one wire at a time so I wouldnt mix them up. There ended up being two unused terminals on the new timer. Once reassembled it seemed most settings on the dial were agitate once the tub was filled with only one small area of the dial for spin and it would only spin a few minutes. So I took the two end covers off the old timer and found two pairs of contacts that looked burnt and flat. I cleaned them up a bit and also noticed the top contact on them should have been bent at 90 deg but was bent outward making a loose connection so I bent them downward so they were level. Reassembled it and it seems to work OK now timer wise. Once the tub bushing and seal come in Im swapping those out to see if that knock is gone. So now I have a new in the box Maytag #204889 timer for $55.00 if anyone needs one.
Post# 866197 , Reply# 80   2/8/2016 at 17:05 (2,971 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 1027737 , Reply# 82   3/22/2019 at 20:25 (1,833 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 1027757 , Reply# 83   3/22/2019 at 21:56 (1,833 days old) by 08roady (Michigan)   |   | |
Thank you, I will check that out. Rob |
