Thread Number: 63029
/ Tag: Modern Dryers
Broke Down |
Post# 856080 , Reply# 1   12/10/2015 at 23:23 (3,031 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 856081 , Reply# 2   12/10/2015 at 23:25 (3,031 days old) by ea56 (Cotati, Calif.)   |   | |
If the dryer is stopping before the load is dry and you are using an auto dry cycle (i.e. sensor dry) the moister sensors may be coated with fabric softener residue. Try wiping them off with a cloth and rubbing alcohol. Be sure the sensor surface is dry before you try to use the dryer. If this doesn't work try using the timed dry setting.
Post# 856137 , Reply# 4   12/11/2015 at 10:54 (3,030 days old) by Yogitunes (New Jersey)   |   | |
an odd thing to always check, or do as a first resort......
unplug the unit, wait a few minutes and plug back in....a lot of times, it resets the unit.....they have been cases, like with the Calypso, you have to unplug for a few days to get rid of the static charge build up..... not that this may exactly fix your issue, but its a simple thing to try, and keep in the back of your head....for some things, it works |
Post# 856185 , Reply# 6   12/11/2015 at 18:55 (3,030 days old) by Supersurgilator (Indiana)   |   | |
Honestly to me it sounds as though the motor maybe going on on thermal overload. I saw a vid once on this a dryer randomly stopping thruoughout the cycle and that was exactly what it was. |
Post# 856487 , Reply# 8   12/13/2015 at 18:44 (3,028 days old) by Brad845 ()   |   | |
Back to the Kenmore set .. Meanwhile dad is going to work on the LG. Thanks everyone.
Post# 856545 , Reply# 9   12/14/2015 at 09:33 (3,027 days old) by LaVidaBoem ()   |   | |
Although not the prettiest girl at the dance, its nice to walk by those, and know, with a single knob, and 1 push button...Simplistic Dependability.
Good Luck, LaVidaBoem |
Post# 856611 , Reply# 10   12/14/2015 at 19:40 (3,027 days old) by Supersurgilator (Indiana)   |   | |
is that a Kenmore 400 series? Does it still do a deep rinse or had they already changed to the partial fill rinse by that time? |
Post# 856907 , Reply# 13   12/16/2015 at 11:31 (3,025 days old) by Brad845 ()   |   | |
Sorry 20 series fridge** |
