Thread Number: 63148
Final drain not complete - Kitchenaide Imperial Dishwasher - Dual Cycle |
Post# 857311 , Reply# 1   12/18/2015 at 15:52 (3,044 days old) by appnut (TX)   |   | |
Post# 857312 , Reply# 2   12/18/2015 at 15:58 (3,044 days old) by scole99 ()   |   | |
Thanks for the feedback...in the event that it is shorter, what is the solution in your opinion? |
Post# 857336 , Reply# 4   12/18/2015 at 18:52 (3,044 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
As suggested above you need to time the drain periods, the final drain period should be at least as long as the other drain periods.
Usually when I have had this problem reported to me the DW is not draining completely at each drain period and the water builds up as the cycle progresses.
But it is easy to listen and see if the water is completely done draining before the drain valve closes and the machine begins filling for the next rinse or wash cycle. You should hear the machine continuing to try to drain for at least 15 seconds after water flow stops before it closes the drain valve and starts filling again.
The most common draining problems with a KA KD 15-16 or 17 DW is either a clogged drain valve as suggested by Steve above or a bad drain impeller.
Other than these likely problems you either have an intermittent drain valve coil that gets hot and goes open, [ you can test by wiring a test light or meter to it and see if the DV closes before the light goes off ] or if you find that the motor and DV are shutting off in less than one minute for the final drain period, you have a bad timer.
