Thread Number: 63265
W Laundromat in new home |
Post# 858457   12/26/2015 at 15:43 (3,036 days old) by moparwash (Pittsburgh,PA )   |   | |
Went to see Greg today..big thanks to him for helping to wrestle this up the steps and into the Traverse....!
This post was last edited 12/26/2015 at 19:27 |
Post# 858459 , Reply# 1   12/26/2015 at 16:43 (3,036 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 858470 , Reply# 2   12/26/2015 at 17:37 (3,036 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 858473 , Reply# 3   12/26/2015 at 18:27 (3,036 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 858476 , Reply# 4   12/26/2015 at 18:45 (3,036 days old) by cuffs054 (MONTICELLO, GA)   |   | |
Damn Frig, you beat me to it! |
Post# 858480 , Reply# 5   12/26/2015 at 18:54 (3,036 days old) by moparwash (Pittsburgh,PA )   |   | |
Since I didn't have the right shoes and apron at the time, I got nothing...cleaned up the outside and took the back off to vacuum the dust out of it...tomorrow Ill take the motor out to get rebuilt..it comes out from the bottom so I have to tip it over... and start checking hoses and wiring...the boot is half-missing...then Ill push it in the basement(I put wheels on it) and take pics with my 1960 dryer
Post# 858499 , Reply# 6   12/26/2015 at 20:21 (3,036 days old) by alr2903 (TN)   |   | |
The Laundromat looks very similar to your dryer. Close enough for 2016. Westinghouse's are so scarce. A |
Post# 858500 , Reply# 7   12/26/2015 at 20:24 (3,036 days old) by scoots (Chattanooga TN)   |   | |
Post# 858566 , Reply# 8   12/27/2015 at 07:26 (3,035 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Wow Jerry where did you find that one?
These 59 through 63 models were the best performing Westinghouse Slant Front laundromats ever. Your machine is the same as my 1959. L1000, I have just about any mechanical part you will need for this machine I even have good door boots. Modern parts in Ohio even has brand-new in the box general electric motors for this machine, I bought one for the L 1000. I would love to see some close-up detail photographs of that dispenser on the top. That machine is quite a Christmas present look forward to talking to you about it. John L. |
Post# 858570 , Reply# 9   12/27/2015 at 08:04 (3,035 days old) by moparwash (Pittsburgh,PA )   |   | |
Thanks, John..
I got it from Greg (Glomain) in the club about 2 hours away in Ohio. Today Ill take the motor out to send it for rebuilding from the same place that did my dryer motor. I didn't plug it in to see what happens and check the belts and hoses and continue cleaning the inside. I took some pics of the bleach dispenser for you. Im still looking for a timer motor for my dryer, so Ill let you know what I need for this one...thanks Jerry This post was last edited 12/27/2015 at 11:40 |
Post# 858571 , Reply# 10   12/27/2015 at 08:12 (3,035 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 858588 , Reply# 11   12/27/2015 at 10:32 (3,035 days old) by golittlesport (California)   |   | |
Post# 858594 , Reply# 12   12/27/2015 at 10:46 (3,035 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 858598 , Reply# 13   12/27/2015 at 11:06 (3,035 days old) by Sudslock1 (St Louis)   |   | |
Hope you enjoy the machine. Will be a good project with great rewards when you get it done. |
Post# 858647 , Reply# 14   12/27/2015 at 17:58 (3,035 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 858660 , Reply# 15   12/27/2015 at 18:49 (3,035 days old) by Ultramatic (New York City)   |   | |
Post# 858902 , Reply# 17   12/29/2015 at 05:35 (3,033 days old) by alr2903 (TN)   |   | |
Post# 858907 , Reply# 18   12/29/2015 at 08:02 (3,033 days old) by moparwash (Pittsburgh,PA )   |   | |
No matter which way you use the dolly...the door and slant front design make it hard for the strap to get a tight grip....you have to wing it...the 59 and up tub weight is a donut around the front of the tub that makes it front heavy. The earlier ones have the tub weights on top of the tub and they are more easily removable. Loading and unloading is easier as the workbench left with the house I took apart had 2 very long and thick boards that fit perfect on the bumper of my Traverse that make a ramp to slide it on and off..before I unloaded it I replaced the legs with wheels to move it around...according to the brochure..it weighs 305lbs..though it seens like much more!
Post# 858924 , Reply# 20   12/29/2015 at 09:09 (3,033 days old) by moparguy (Virginia)   |   | |
I am just catching up and seeing this, what a beautiful Westinghouse, congratulations on such a fine Christmas present to yourself! |
Post# 860950 , Reply# 22   1/9/2016 at 20:28 (3,022 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 860953 , Reply# 23   1/9/2016 at 20:47 (3,022 days old) by seeitrun2006 (Commerce, GA)   |   | |
For the quick rely!!! It was drivng me crazy trying to it out figure!!! |
