Thread Number: 63298  /  Tag: Modern Automatic Washers
GE washer gear oil, transmission, belt and motor.
Post# 858874   12/28/2015 at 22:53 (3,031 days old) by GELaundry4ever (Nacogdoches, TX, USA)
Hello everybody. What can you tell me about the GE washer gear oil? How heavy is the gear oil? I noticed as I observed the drive system setup that the gear oil was a heavy duty type oil. I could be wrong. Please correct me. I noticed that the transmissions seem to be durable, as far as my GE washer is concerned. The belt seems to be built to industrial grade standards too. 15 years old and it hasn't skipped a beat nor deteriorated. How tough are the GE washer motors? Mine seems to be heavy duty quality. Please answer my questions. I'd like to know. Thank you.
Post# 858938 , Reply# 1   12/29/2015 at 11:03 (3,031 days old) by LaVidaBoem ()
I use my blend>>
Hello,
I will probably get flamed,
but I have been using 15W-90 Shell gear oil...with 1 quart of Marvel Mystery Oil.
>>Edited: Wrong...Shell Donax 80W-90...I use 15W-40 Oil...Gettin' Old<<
Long History of Marvel and in the tranny biz...some great stuff before friction modifiers became so prevalent in Dexron III.
I put the marvel into a 1 gallon jug, top off with the 80W-90.
Only used in the tranny's (washers) that I work on...Whirlpool, Kenmore, GE, Frigidaire, and Maytag.
Although I know it won't hurt it, let some others tell what they use.
Hope this Helps,
LaVidaBoem
This post was last edited 12/29/2015 at 11:48
