Thread Number: 6330
Kitchenaid Detergent Cup Question... |
Post# 128272 , Reply# 1   5/12/2006 at 11:17 (6,551 days old) by brent-aucoin ()   |   | |
In Case I did not make any sense.... This is what I am talking about when I say metal thingy's. Brent |
Post# 128276 , Reply# 2   5/12/2006 at 11:33 (6,551 days old) by lightedcontrols ()   |   | |
Those are just pins and will pull out with needle nose pliers. |
Post# 128285 , Reply# 3   5/12/2006 at 12:27 (6,551 days old) by coldspot66 (Plymouth, Mass)   |   | |
That cup comes as an assembly....you can't buy the gaskets that go inside the trip levers. Part # is 9740171. Hope this helps! |
Post# 128295 , Reply# 6   5/12/2006 at 13:33 (6,551 days old) by unimatic1140 (Minneapolis)   |   | |
Post# 128300 , Reply# 7   5/12/2006 at 14:05 (6,551 days old) by gadgetgary (Bristol,CT)   |   | |
I too had a similar problem with my KA(KUDS220T4). The prewash compartment would not freely open and close. I simply filled the main wash compartment, closed it and then put detergent in the prewash(which would dump directly into the tub upon closing the door). When the serviceman came to repair my Maytag Neptune(remember all those recalls with the washer not spinning and the replacement of the board and wax motor----Don't get me started on that one again!), I asked him to take a look at my KA dishwasher detergent cup. When he took off the front panel, he too discovered that is was 'gummed up', probably from a brief time of using liquid detergent. He simply cleaned that junk out and VIOLA~!.......the dispenser was working like brand new. And there was no charge for that service either! I will definitely use that repairman again should anything else in my home need attentive prompt service. Gary P.S. Make the torrential rain go away here in CT. |
Post# 128313 , Reply# 8   5/12/2006 at 15:09 (6,551 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
