Thread Number: 6339
Newer Kitchenaid Dishwasher --- Sad to say the least! |
Post# 128477 , Reply# 1   5/13/2006 at 08:57 (6,551 days old) by panthera (Rocky Mountains)   |   | |
I was shocked (not literally) when I saw the underside of my folk's Frigidaire. How it keeps from leaking is the real mystery. I don't know how it got through the UL testing. Maybe it didn't? These machines have had every ounce of quality designed out of them. That thing is held together with screws sunk directly into the plastic tub - one repair and they are so loose, no idea how they should hold up to vibration. Their same age Maytag is a bit better, but not very confidence inspiring. I've taken it on the chin here for critising US quality, but this is scary. US companies wouldn't have sold that sort of stuff 30 years ago for fear the in-warranty costs would bankrupt their service departments. What on earth are folks thinking? These are not inexpensive but very cheap machines! |
Post# 128585 , Reply# 2   5/13/2006 at 17:51 (6,550 days old) by sudsmaster (SF Bay Area, California)   |   | |
Well, I can say that my Bosch SHU43CU absolutely must run with the door closed. In fact you have to wait a few seconds after unlatching the door before opening it, if you don't want to get sprayed. Too bad the new KA's are built so flimsy. I knew this was a problem with Frigidaire - my model was so rickety that the upper rack would routinely fall off its tracks, and the recirculation filter was so poorly designed it would let major food particles like sunflower seeds through to clog the spray arms (or redeposit on the dishes). You might want to hook the machine up to a hot water tap and run a load of dirty dishes through it, just to see if it cleans at all. You might also check for a clogged spray tube or defective spray pump. A summer drizzle just doesn't sound right to me. |
Post# 129246 , Reply# 5   5/16/2006 at 23:07 (6,547 days old) by johnb300m (Chicago)   |   | |
are you serious? i had no idea the new tall tub WPKA machines where so horrible. i knew they had issues...I'm perplexed. Our GE Triton XL fills with very little water also, but there is no cavitation, the pump runs at full pressure. How are they able to do it? but not WP? I guess this enforces my recommendations pertaining to new tall tub machines to be GE and Maytag..... though, i've very worried as to what WP is going to do to Matag's dishwashers, which are very good right now. |
Post# 129247 , Reply# 6   5/16/2006 at 23:09 (6,547 days old) by johnb300m (Chicago)   |   | |
Brent, you should tell KA about this on their dishwasher forum they have! People need to know. And if enough bad press is spread, maybe WP will fix this crappy system. CLICK HERE TO GO TO johnb300m's LINK |
Post# 129270 , Reply# 7   5/17/2006 at 06:54 (6,547 days old) by panthera (Rocky Mountains)   |   | |
no way would they put it up on their site. I just went there, and now I think I need to go find a diabetic and beg some insulin. What a discustingly sugar-sweet amount of "we are the best" nonsense. Horrid. Interesting side note, the "best machines" in their contest - whatever that was - were built from 1949-51. Of course they made no mention of the fact that they were not from them. Sheesh - everything bad I said about using a good brand name to sell bad stuff - just take it and mulitply by 10. Now to go find something against the sugar shock. |
Post# 129290 , Reply# 9   5/17/2006 at 08:10 (6,547 days old) by appnut (TX)   |   | |
Post# 129401 , Reply# 12   5/17/2006 at 16:39 (6,546 days old) by johnb300m (Chicago)   |   | |
I agree. It seems that all the standard tub dishwashers are the way to go if you can get their hands on them. They seem to be the only machines worthy of the name "dishwasher." I went to Lowe's today and inspected the Maytag tall tubs. I was, nevertheless, impressed with them. they didn't cross my mind as "garbage". The plastic tub ones seemed ok, but i didn't take them out and check tub thickness. The Maytag stainless steel ones did seem more durable. As far as the standard tub maytags with that center tower gizmo, they have always gotten great reviews from relatives. Like I said, we have 2003 GE Triton XL and it is by far the best tall tub machine i've ever seen. The newest GE tall tubs seem to be the same, though with smaller jets...i don't know why. But i'd recommend those for a tall tub machine, and as far as i know, GE machines still do a minimum of 2 rinses. |
Post# 129653 , Reply# 14   5/18/2006 at 15:56 (6,545 days old) by johnb300m (Chicago)   |   | |
I was at my Lowe's today, filling out an application [hopefully for the appliance dept.] and went to look at the tall tub Maytags even further. The last time i looked at Maytag was at the Menards, and all their machines were kinda junky. Now these Lowe's machines on the other hand were very nice machines. I was able to lean a few forward and did not find the plastic tubs on the Maytags to be any thinner or thicker than the GE or Whirlpool machines. they all looked to be within the same thickness. Now unless the Maytag plastic reacts funny to heat and has a lower plasticity point, well i don't know. Until Whirlpool rapes Maytag, i will continue to endorse the Maytag and GE tall tub machines, and inform all i know to avoid Whirlpool's tall tub machines like the plague. ALSO: for the low water pressure in that KitchenAid...Brent, did you check that chopper screen? it could be blocked. for some reason i've heard tons of complaints about that chopper screen clogging up, starving the pump of water. I say this because until i see it in person with a BRAND NEW machine, i refuse to believe Whirlpool would be stupid enough to use pump cavitation as a means to save water and wash dishes. There must be something clogged. As far as many complaints from people saying crud collects in their corner glassware in the upper rack. i do notice that these middle arms are kinda short and do not reach the corners too well. Even in our awesome GE Triton XL at home, if cups are of a certain dimension, the middle arm will not get water into the corner cups. Personal observations and opinions.......agree? disagree? have at it. |
Post# 129716 , Reply# 17   5/18/2006 at 20:46 (6,545 days old) by brent-aucoin ()   |   | |
Sorry for the double post. I got kicked off, and had no idea that the other went through. Brent |
Post# 129720 , Reply# 18   5/18/2006 at 21:00 (6,545 days old) by appnut (TX)   |   | |
Post# 129959 , Reply# 22   5/19/2006 at 18:16 (6,544 days old) by johnb300m (Chicago)   |   | |
Post# 130045 , Reply# 24   5/19/2006 at 22:29 (6,544 days old) by sudsmaster (SF Bay Area, California)   |   | |
Post# 130048 , Reply# 25   5/19/2006 at 22:35 (6,544 days old) by toggleswitch (New York City, NY)   |   | |
Post# 130061 , Reply# 26   5/19/2006 at 23:30 (6,544 days old) by peteski50 (New York)   |   | |
When I renovated my kitchen almost 5 years ago I had a portable whirlpool power clean. Loved it and was going to build it into new cabinets. Some people talked me out of it. I was buying a new range at Sears. So I went for the Kenmore tall tub (they were only) out about one year. Needless to say I was so disappointed. The glasses loaded in the top corners didnt get clean. Dishes washed decently but nothing like the power clean whirlpool. I had it for a year in a half the circuit board blew out twice. Even though Sears was willing to fix it I went back and demanded to get another dishwasher. Really disappointed. They tried to get me to buy the SS model but I said it's the same S__T. I decided on the GE tall tub because it was the most durable of the plastic tall tubs. I am very happy with it. I got the 7700 model next to the TOL at that time. It washes really well. (What a difference). Very good cycle selection / options with easy to read controls with digital display. Problem with most of the new DW's today they don't give any type of progress status on control panel. Also I dont like the one with the undermount controls. I like to see all indicators and believe me I wish for a Window also. Will we ever see the day? As much as I like the GE tall tub I still regret giving up the Whirlpool power clean!! Lets start designing our own!! Peter |
Post# 130077 , Reply# 27   5/20/2006 at 02:37 (6,544 days old) by johnb300m (Chicago)   |   | |
I was able to verify with someone that the tall tub whirlpool dishwashers ARE supposed to have a fairly powerful spray. Not many machines today will have the power of the "huricane in a box" but the tall tubs do have "powerful" jets. I was able to see a tall tub "Kenmore" today at a Sears in Rockford, IL with a clear front. the jets seemed pretty decent. [this may be preaching to the choir here] I was told that many of the washability issues are with the way things are loaded in the top rack and if the middle spray arm is blocked. As well as the chopper assembly breaking and clogging. It just doesn't keep itself clean as well as the PowerClean. Apparently these machines work very well with no soil, and are the most finicky of the bunch. The issue with "weak" pressure must be fault in the dishwasher. I do hear that these motors go out alot, they are shitty motors and it may not be running at full speed??? |
Post# 130078 , Reply# 28   5/20/2006 at 02:54 (6,544 days old) by panthera (Rocky Mountains)   |   | |
That comment gets me wondering. As everyone has by now figured out, I am fixin' to go back to the 'States. With my parents health problems after that car crash, probably indefinitely...After living abroad for over 20 years, so much has changed that every visit back is a major culture shock. One interesting constant over all these years: Here in Germany I have had exactly two dishwashers. The first was killed by the movers (falling down stone stairs will do that to you). That Miele lasted from 1979 'till 2000. My current Miele has never needed a repair (nor did the old one, except for a lower-rack wheel. Once). Now lets see, I left in 1983. At my parent's house: Lady Kenmore fails and kitchen under water. 1987: Whirlpool something or other fails and repair would cost more than new one. 1991: Last Monkey Wards chokes to death on olive pit (plastic filter had come loose by itself) 1995: GE Modern Maid from 1963 which I had installed in 1991 is banished for being "too old" by my brother, Whirlpool installed. Oh, the GE is still running in the neighbour's kitchen in 2006. 1997: Whirlpool motor fails due to leak and would cost more to repair than...been there, done, that. 2000: Newest Whirlpool has now had new timer, soap dispenser, motor, tower - all under warranty. Dealer says must have been dropped in transit. Yeah, whatever. 2005: Firgidaire from spring has been repaired twice. Maytag not yet, but needs three hours for wash... 2006: Keven flys over with a Miele as carry on... Sheesh, why oh why do Americans put up with this crap? |
Post# 130278 , Reply# 30   5/20/2006 at 22:43 (6,543 days old) by johnb300m (Chicago)   |   | |
Post# 130283 , Reply# 31   5/20/2006 at 23:30 (6,543 days old) by appnut (TX)   |   | |
Post# 130299 , Reply# 32   5/21/2006 at 00:54 (6,543 days old) by roto204 (Tucson, AZ)   |   | |
Love the SmartDispense--reminiscent of the Tappan that cleaned nothing but stored liquid hand-dishwashing soap in the door and dispensed it in metered doses. Looks like a fantastic dishwasher from the modern era... ...although if you have time to knit a sweater, the cycle time must be long. You have to love Alton Brown, though...especially the dishwasher "simulation"... |
Post# 130306 , Reply# 33   5/21/2006 at 01:30 (6,543 days old) by peteski50 (New York)   |   | |
