Thread Number: 63444  /  Tag: Modern Automatic Washers
Whirlpool Duet Dispenser motor bypass?
scroll >>> for more items
Post# 860236   1/5/2016 at 13:40 (895 days old) by rwindiana (Indiana)
Hello all. I've got a dispenser motor that is getting stuck and needs to be banged on about every other wash on my Duet (GHW9150PW1). Before I order a new one, I was wondering if it's possible to bypass it entirely? The dispenser itself is barely ever used and we could do without it. Just thought I'd ask. :) Thanks!
Post# 860247 , Reply# 1   1/5/2016 at 14:49 (895 days old) by mrb627 (Buford, GA)
Dispensing
mrb627's profile picture
Other than dispensing at the right time, what is the issue?
Is it causing some other problem?
Malcolm
Post# 860249 , Reply# 2   1/5/2016 at 14:58 (895 days old) by rwindiana (Indiana)
Sorry I wasn't specific :) it completely locks up the washer with error code "f13" and won't run again until the motor turns again.
Post# 860269 , Reply# 3   1/5/2016 at 16:55 (895 days old) by logixx (Germany)
logixx's profile picture
The washer "communicates" with the dispenser motor. If the motor doesn't signal that it is positioned correctly, the washer will give an error code - as you know now. You might find a cheap used spare online or someone here could tell you how to fix it, if possible.
Post# 860272 , Reply# 4   1/5/2016 at 17:00 (895 days old) by logixx (Germany)
Service manual
Post# 860381 , Reply# 5   1/6/2016 at 06:30 (894 days old) by mrb627 (Buford, GA)
Motor Binding?
Is the motor simply binding at the diverter?
Maybe you can disassemble and clean the dispenser enclosure, if not done so already. At least before you start looking for parts.
My recollection of the dispenser drive mechanism is quite fuzzy.
Malcolm
Post# 860408 , Reply# 6   1/6/2016 at 10:10 (894 days old) by rwindiana (Indiana)
The problem is definitely in the motor itself. I might try disassembling that. Meanwhile, I just ordered another one.
I was hoping that I could just disable the dispenser position check in the program somehow, but I'm guessing that would actually take a reprogramming of the computer. Too bad it's not like my old Leading Edge PC. Every component can be enabled or disabled with a simple jumper setting or DIP switch. :)
