Thread Number: 63475
/ Tag: Ranges, Stoves, Ovens
Vintage range:Front burner only gets a little warm on med-lo, doesn't work on higher settings |
Post# 860567   1/7/2016 at 12:51 (3,025 days old) by Shantastic81 (SW WA)   |   | |
Post# 860568 , Reply# 1   1/7/2016 at 12:53 (3,025 days old) by Shantastic81 (SW WA)   |   | |
Post# 860640 , Reply# 2   1/7/2016 at 21:33 (3,025 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Sounds like you have a switch problem. I don't have parts info for this range, but if you unplug the range and remove the panel behind the controls, there should be a part number on the switch body.
Someone may chime in with the part number before you have to do that, it's a beautiful range and I'll bet you won't have much trouble getting it right again. Well worth saving, for sure. |
Post# 860649 , Reply# 3   1/7/2016 at 22:32 (3,025 days old) by rp2813 (Sannazay)   |   | |
Post# 861091 , Reply# 4   1/10/2016 at 18:08 (3,022 days old) by Shantastic81 (SW WA)   |   | |
Post# 861103 , Reply# 5   1/10/2016 at 19:15 (3,022 days old) by rp2813 (Sannazay)   |   | |
Post# 861104 , Reply# 6   1/10/2016 at 19:20 (3,022 days old) by norgeway (mocksville n c )   |   | |
BEAUTIFUL....If you ever need anything, I stripped a 40 inch 59, so I have a few switches and units.I had about forgot about them. |
Post# 863757 , Reply# 7   1/23/2016 at 23:44 (3,009 days old) by Shantastic81 (SW WA)   |   | |
