Thread Number: 63478  /  Tag: Other Home Products or Autos
What happens when a propane appliance is connected to Nat. Gas?
scroll >>> for more items
Post# 860579   1/7/2016 at 14:06 (777 days old) by MattL (Flushing, MI)
Just wondering.  I know you have to change the orifice and such to convert to propane, but what effect would that have if the appliance is connected to natural gas without replacing the orifice?
Post# 860582 , Reply# 1   1/7/2016 at 14:15 (777 days old) by norgeway (mocksville n c )
You will have
hardly any flame, if you hook up propane to a natural gas range you will have a blowtorch with 3 or 4 foot flames, Most orifices are adjustable for either gas.
Post# 860585 , Reply# 2   1/7/2016 at 14:50 (777 days old) by cuffs054 (MONTICELLO, GA)
Yeah, what Norgeway said! Installer changed only one of the ovens in MT Gemini to run on propane. I fired (literally) up the top oven and quickly noticed the problem!
Post# 860587 , Reply# 3   1/7/2016 at 15:23 (777 days old) by MattL (Flushing, MI)
I'm trying to figure out if that is the issue with a dryer I bought on CL.  I have no idea if it was converted to propane, but it will not fire on nat. gas.  did all the usual things, replaced the coil pack and igniter, no go.
Post# 860590 , Reply# 4   1/7/2016 at 15:36 (777 days old) by alr2903 (TN)
There is a sensor that monitors the igniter for heat before the gas valve will open.
Post# 860606 , Reply# 5   1/7/2016 at 17:15 (777 days old) by MattL (Flushing, MI)
YEs, all sensors are good, every component checks out fine, igniter glows.  Just not sure about the orifice and related insert into the valve.  Bought this 6 or 7 moths ago, seller said it worked but occasionally needed two cycles to get the clothes dry.  Just not sure if it was set up for reg. gas or propane.
Post# 860623 , Reply# 6   1/7/2016 at 19:59 (777 days old) by arris (Rochester New York)
Conversion
arris's profile picture
From LP to Nat gas as stated will not have a large flame but the other way around " Watch out !!! " not only does propane require a smaller orfice, but propane is a higher pressure resulting in the adjustment to the valve... it's also heavier than air and Nat gas.... which if leaking will settle to the floor.....
Post# 860625 , Reply# 7   1/7/2016 at 20:12 (777 days old) by wayupnorth (On a lake between Bangor and Bar Harbor)
wayupnorth's profile picture
From what I was told by a person involved in this areas natural gas expansion, propane will do exactly what norgeway said, turn into a blowtorch. As propane is a much more refined gas that has to be filled to a certain temperature level in the tank. I dont understand why but he said propane is much volatile than natural gas. Thats why it costs more. I have propane here and no chance of getting cheaper natural gas here where I am, less than 10 miles from a pipeline.
Post# 860638 , Reply# 8   1/7/2016 at 21:32 (777 days old) by delaneymeegan (Mary Richards lived here)
delaneymeegan's profile picture
Did you bleed the line?
Before connecting the flex connector to the dryer back, which should be the LAST location to connect, you need to turn the gas on for a second or two, and get the air out of the pipe.
Then connect the gas line to the dryer (or any appliances) but not tight. Turn the gas on again for a few seconds and let the gas into the piping in the dryer and hopefully push the air out.
Then tighten the nut.
I had this situation where I sold a standing pilot Maytag dryer to someone and they put on a nice long 4' or 5' flex connector, but didn't bleed the line.
So they're trying to light the pilot and there is nothing there for obvious reasons.
Post# 860639 , Reply# 9   1/7/2016 at 21:33 (777 days old) by MattL (Flushing, MI)
What I'm wondering is if the orifice is too small to operate with nat. gas.
Everything checks out, there is power to the coils, the igniter fires, just no gas.  It's got to be very rare for a gas valve to fail, it could but I'd guess that would be the last thing to go.
Post# 860641 , Reply# 10   1/7/2016 at 21:35 (777 days old) by gansky1 (Omaha, The Home of the TV Dinner!)
gansky1's profile picture
What make and model dryer is this?
I've had a couple of dryers with bad valves in them, not real common, but it does happen.
Post# 860656 , Reply# 11   1/7/2016 at 23:29 (777 days old) by MattL (Flushing, MI)
Duet.  GGw9200Lw0
Post# 860669 , Reply# 12   1/8/2016 at 06:52 (777 days old) by arbilab (Ft Worth TX (Ridglea))
Matt, I've seen gas coil ass'ys with power and continuity fail to open the valve and replacing the coil restored full operation. It can't be 'that' unusual, or they wouldn't sell the coil alone.
Very glad I didn't have to disturb the gas plumbing, not comfortable doing that.
Post# 860776 , Reply# 13   1/8/2016 at 23:31 (776 days old) by MattL (Flushing, MI)
As I mentioned I replaced the coil pack, with no improvement.  Only thing left to go bad is the valve itself. Frustrating.
Post# 860821 , Reply# 14   1/9/2016 at 06:34 (776 days old) by arbilab (Ft Worth TX (Ridglea))
Oh, missed that.
Do you get the 'clank' of the valve actuating? Does the glowbar ever extinguish (probly shouldn't if no ignition takes place)?
Post# 860923 , Reply# 15   1/9/2016 at 17:58 (775 days old) by MattL (Flushing, MI)
Yes to everything but the "click".  I may have to break down and buy a used valve on ebay.  My "cheap" dryer is now costing a lot more...
If it was vintage I'd mind less, but it's only 8 years or so old.
Post# 860999 , Reply# 16   1/10/2016 at 04:44 (775 days old) by sudsmaster (East of SF, West of Eden, California)
sudsmaster's profile picture
Speaking of propane vs natural gas...
Costco has offered from time to time a dual fuel generator, which can run on either gasoline or propane. Fine. But what I don't understand is why the company (Champion, as I recall) doesn't also offer a conversion kit to change from propane to natural gas. All it would require would be a larger fuel jet and possibly a different pressure regulator.
Maybe they figure the generator, being portable (heavy but with wheels) might try to walk away from a plumbed gas connection, and therefore be a safety hazard? My answer to that would be to take off the darn wheels so it's stable, and use a flex hose connection, with a nice ball valve to shut the gas off when it's not in use.
Not that I need one. I have a small two stroke 900 watt generator for extreme emergencies (or car camping) and used it only once, when I bought it, to make sure it actually worked. LOL.
Post# 861015 , Reply# 17   1/10/2016 at 08:57 (775 days old) by gansky1 (Omaha, The Home of the TV Dinner!)
I had the same thing happen with a "good deal" 27" Whirlpool dryer - all else having failed, I replaced the entire valve assembly and solved the problem. I got the dryer in a deal with some other washer and eventually sold them both so I did recoup my costs. I can get parts at "trade" pricing from my local parts company (Sundberg) so the cost wasn't too bad IIRC, about $80.
Post# 861144 , Reply# 18   1/11/2016 at 01:20 (774 days old) by MattL (Flushing, MI)
Yeah, I'm going to break down and buy a used valve on ebay ~$30.  At that point I'll have a little over $100 into the machine, which I was trying to avoid.
My Kenmore dryer from the mid 90's has a motor issue, new motor  was $150 so I said no, and opted to go this route.  Second motor to go bad in that dryer-  after one load it's unable to start unless I give the drum a turn  -- had to bypass the door switch.
Post# 864426 , Reply# 19   1/28/2016 at 00:07 (757 days old) by MattL (Flushing, MI)
Just an update.  Bought a used gas valve on Ebay, asking $29, offered $23 and the seller took the offer.  Had about $9 in eBay bucks so cost was low.  Connected the wires to the valve before I tore the old one out and it clicks on and off as it should.  I appears one coil is energized when the dryer powers on, it clicked right away.  Got a second click after the igniter did it's thing.
Only issue is the connection is different than the one I have.  Mine has a curved gas pipe feeding the valve, the replacement has a brass flare fitting.  I'm hoping it won't be difficult to find the right fittings.
Moral of the story, yes gas valves do fail...
