Thread Number: 63610
/ Tag: Modern Dryers
Miele Dryer - 400V or 230V? |
Post# 861835   1/14/2016 at 14:21 (3,023 days old) by jlbrazil (brazil)   |   | |
Hi guys, I need some help. I found a T88-35C CH to sell, but I wanted to know if it only works on 400V. Does anybody know? Thanks, Joao. |
Post# 861839 , Reply# 1   1/14/2016 at 14:28 (3,023 days old) by logixx (Germany)   |   | |
I guess it's either 230 or 400V.
Post# 861840 , Reply# 2   1/14/2016 at 14:35 (3,023 days old) by jlbrazil (brazil)   |   | |
I was thinking that 230V/2,14 kW referred to the T8835C and 400V/2,85kW to the T88-35C CH. |
Post# 861848 , Reply# 3   1/14/2016 at 15:00 (3,023 days old) by logixx (Germany)   |   | |
Post# 861853 , Reply# 4   1/14/2016 at 15:54 (3,023 days old) by jlbrazil (brazil)   |   | |
Logixx, do you know if a 50 Hz draining pump works fine on 60Hz? |
Post# 861857 , Reply# 5   1/14/2016 at 16:15 (3,023 days old) by logixx (Germany)   |   | |
Post# 861877 , Reply# 6   1/14/2016 at 18:52 (3,022 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Is that unless otherwise specified their washers and dryers will not operate properly when connected to frequency different than specified.
That being said some Miele parts in their laundry appliances are 60hz/50hz. One assumes this is get out of making different versions of a part for the small markets such as USA and elsewhere that use 60hz. Best way to tell is to open the dryer and look at the part in question. The rating plate should say. That being said the pump may not care about spinning 10% faster. |
