Thread Number: 63668
/ Tag: Ranges, Stoves, Ovens
P7 Sensi Temp Conversion Question |
Post# 865973 , Reply# 1   2/7/2016 at 12:53 (2,972 days old) by Psychoelf (Lewisburg)   |   | |
Still needing help if anyone has an answer. Thanks! |
Post# 866046 , Reply# 3   2/7/2016 at 22:00 (2,972 days old) by Kenmore71 (Minneapolis, MN)   |   | |
Post# 866712 , Reply# 5   2/11/2016 at 19:32 (2,968 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 866715 , Reply# 6   2/11/2016 at 19:46 (2,968 days old) by norgeway (mocksville n c )   |   | |
John knows what he is talking about! |
Post# 866823 , Reply# 7   2/12/2016 at 14:44 (2,967 days old) by Psychoelf (Lewisburg)   |   | |
Awesome! I'll try to post back once I get it in there. |
Post# 879534 , Reply# 8   5/4/2016 at 04:19 (2,886 days old) by Xraytech (Rural southwest Pennsylvania )   |   | |
Post# 879638 , Reply# 9   5/5/2016 at 04:57 (2,885 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
All that is really needed is a Robertshaw Non-Push-To-Turn infinite switch to make the element work again.
Normally I would leave the old inoperative sensor in place, it is just not connected electrically.
Another issue is the temperature dial is not labeled properly for a regular infinite switch, but it is fairly easy to learn to use it this way.
When GE sold kits especially for converting STs to regular infinite switches they included a new knob or dial that often matched the other knobs-dials on the range.
I always leave the 4-6-8-Griddle switch hooked up so you can continue to enjoy the benefits this versatile multi-size element.
Post# 897310 , Reply# 11   9/5/2016 at 17:06 (2,761 days old) by Psychoelf (Lewisburg)   |   | |
Disregard the above. I assumed....Then I read the diagram more in depth and its working now. Just had to make a wire for the L2 and take the tranformer wires off for the 12 volt side. Griddle and pushbuttons all work! |
