Thread Number: 63979
/ Tag: Classified Ad Finds
Pants presser |
Post# 865540   2/4/2016 at 16:58 (2,974 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 865544 , Reply# 1   2/4/2016 at 17:26 (2,974 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Actually the thing is a flat plate ironer and it was sold in competition with roller ironers or mangles. When CU rated ironing appliances, this type of machine was judged slower, even with flat pieces. |
Post# 865716 , Reply# 2   2/5/2016 at 19:19 (2,973 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
No, didn't really like flat plate ironers. Most of the quibbles came from the endless positioning required and limits on doing "fancy" garments items.
Have three flat plate ironers (two vintage Hurley and one Elna) and while they do have their uses mostly stick with one of my ironers. Where flat plate presses do shine is the ability to do several layers at once. This is handy because for sheets and table cloths you *will* be folding them in half or quarters because they just won't fit otherwise. Where flat plate ironers do shine is in their traditional use in laundries/dry cleaners; pressing garments/textiles instead of ironing. Trouser, jackets, lace table textiles, that sort of thing. A few of our members have GE flat plate ironers: www.automaticwasher.org/cgi-bin/T... |
Post# 865870 , Reply# 3   2/6/2016 at 20:24 (2,972 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Contour/fitted bed sheets are easier done on a press rather than fighting to get them through an ironer. It does vary but those with elastic all way around edges are a chore to do on an ironer, but easier to do on a press, especially if folded into quarters.
Commercial laundry workers refer to positioning things on the press buck as "lays". Depending upon what is being pressed and the size of the buck (the ironing board part of the press if you will), and how it is shaped you can be moving things around quite a lot. Trick is to know how to go about things so you don't muss up sections already done when moving on. When you are ready to run with the big dogs: |
Post# 865885 , Reply# 4   2/6/2016 at 22:03 (2,972 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 865887 , Reply# 5   2/6/2016 at 22:14 (2,972 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Aren't sold in the USA. You might find one someone brought over with them on eBay or CL. That and or being offered for sale on fleapay with international shipping.
Problem would be the voltage requirements. If the thing doesn't mind "American" 208v -240v (two hots, a ground and separate neutral) then you'll be fine. OTOH if it will only work with European power you'll need a pretty large sized transformer that can handle the power load. www.amazon.co.uk/Blanca-Press-PSV... www.blancapress.co.uk/... |
Post# 865889 , Reply# 6   2/6/2016 at 22:38 (2,972 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Thanks Launderess -
1) I just found one in Asheville, a little ride from here, but not so far. I realised that it wasn't sold in the USA when my searching ended up on Amazon.uk.com. So, whoever is selling it, I'd have to make sure (as it's used) that it would work with US voltage. There's no indication it would, though. (see link) 2) Another one - which I'm not familiar with - Steamfast, here on CL : atlanta.craigslist.org/atl/app/54... CLICK HERE TO GO TO ovrphil's LINK on Asheville Craigslist |
Post# 865892 , Reply# 7   2/6/2016 at 23:17 (2,972 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
As don't require both units.
The "steam press" looks like one of the Chinese knockoffs of famous Singer Press. Looking at the specs don't see why the BP wouldn't run on American "220" power. But best ask the owner. www.ironingsupplies.co.uk/Blanca-... |
Post# 865920 , Reply# 9   2/7/2016 at 07:04 (2,972 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Launderess - we aren't rushing out to buy right now - would not want to really do shipping costs; just pick up local. But I will keep in mind, the Hurley. :-) Thank you. Speaking of Singer...Amazon sells that one and I wondered if it was just a cheap chi-knees product.
I didn't see any sign of safety there - you either moved fast enough out of the way or get folded into the garment, it appeared. |
Post# 866065 , Reply# 10   2/8/2016 at 01:44 (2,971 days old) by tolivac (greenville nc)   |   | |
Don't hink that presser would meet US OSHA safety standards-they would require a presence sensor-light curtain,Ultrsound sensor,etc that would prevent the press platen from descending on the operator unless he was clear of the sensors. |
Post# 866077 , Reply# 11   2/8/2016 at 06:08 (2,971 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Or have the switch to lower the plate located 6 feet away, bolted to the floor or wall. |
