Thread Number: 64223
Whirlpool Duet HT GHW300PW4 Help!!! |
Post# 868019 , Reply# 1   2/20/2016 at 10:33 (2,986 days old) by electroluxxxx (Syracuse NY)   |   | |
Post# 868108 , Reply# 4   2/21/2016 at 00:22 (2,986 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
The tub will move side to side and up and down with the movement of the suspension system.
I would think you would hear some thunking and grinding as the drum hits the outer tub if it is the spider. Also there should be some noise as it is just tumbling on the regular cycle with it not being fully supported by the spider.
Not a repairman, just typing out loud as I think.
Post# 868110 , Reply# 5   2/21/2016 at 00:30 (2,986 days old) by electroluxxxx (Syracuse NY)   |   | |
this is the inner tub that moves up and down, the suspension and springs are working as they should. its almost as if the spider is held together because I cannot pull forward on the inner tub which is a good sign I would think. |
Post# 868980 , Reply# 8   2/25/2016 at 08:30 (2,982 days old) by vacerator (Macomb, Michigan)   |   | |
Nice newer Duet. I think you made a wise choice. Does it have the vent fan in it? |
