Thread Number: 64330
Is this a 90s Maytag DC variant? |
Post# 869240 , Reply# 1   2/26/2016 at 14:30 (2,981 days old) by Runematic (southcentral pa)   |   | |
Post# 869261 , Reply# 2   2/26/2016 at 16:31 (2,980 days old) by vacerator (Macomb, Michigan)   |   | |
That is not a Peforma Maytag. Performas had the thick top on them. They were Norges built at the Searcy Arkansas plant. |
Post# 869263 , Reply# 3   2/26/2016 at 16:34 (2,980 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 869285 , Reply# 5   2/26/2016 at 18:11 (2,980 days old) by appnut (TX)   |   | |
Post# 869296 , Reply# 6   2/26/2016 at 18:45 (2,980 days old) by vacerator (Macomb, Michigan)   |   | |
All I can read on it is Maytag. |
Post# 869298 , Reply# 7   2/26/2016 at 18:48 (2,980 days old) by vacerator (Macomb, Michigan)   |   | |
Those were sold in Holland? That might explain the odd configuration. I've never seen one. I've seen Neptunes, Atlantis, then Maytag closed up shop. A few of the family are in the blue cheese business up in Newton Iowa. |
Post# 869321 , Reply# 8   2/26/2016 at 22:55 (2,980 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 869349 , Reply# 9   2/27/2016 at 05:13 (2,980 days old) by vacerator (Macomb, Michigan)   |   | |
Well, I just did look at his console swap!!!!!! Case solved. I wake up early for a reason. |
Post# 869373 , Reply# 10   2/27/2016 at 07:45 (2,980 days old) by runematic (southcentral pa)   |   | |
This is most definitely a Dependable Care washer with the Performa name on it, like I said before. I sold many of these washers new & used. They had this washer out at the same time as the Norgetag Performa and the control panels had the same stripes on them. I know the difference between the two platforms, believe me. Oh, and the Norgetag Performas weren't built in Searcy. |
Post# 869398 , Reply# 11   2/27/2016 at 12:06 (2,980 days old) by vacerator (Macomb, Michigan)   |   | |
I believe you. Who the heck was running Maytag? |
Post# 869401 , Reply# 12   2/27/2016 at 12:14 (2,980 days old) by appnut (TX)   |   | |
Post# 869416 , Reply# 13   2/27/2016 at 13:57 (2,980 days old) by vacerator (Macomb, Michigan)   |   | |
That's when Maytag began having problems. |
Post# 869437 , Reply# 14   2/27/2016 at 15:09 (2,980 days old) by mrb627 (Buford, GA)   |   | |
Post# 869439 , Reply# 15   2/27/2016 at 15:26 (2,980 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 869465 , Reply# 16   2/27/2016 at 18:16 (2,979 days old) by vacerator (Macomb, Michigan)   |   | |
Not recognizing the Whirlpool Clyde division dual action agitator? |
Post# 869496 , Reply# 17   2/27/2016 at 22:24 (2,979 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 869506 , Reply# 18   2/27/2016 at 23:19 (2,979 days old) by DADoES (TX, U.S. of A.)   |   | |
Per the parts diagram, SAV505DAWW or SAV505DAWQ is an Amanatag of some ilk ... or a Norgetag, I'm not clear on the difference between those two designs. Anyway, it shows a single belt (transmission drive) with idler pulley and direct-drive pump. CLICK HERE TO GO TO DADoES's LINK |
Post# 869542 , Reply# 19   2/28/2016 at 08:17 (2,979 days old) by runematic (southcentral pa)   |   | |
This SAV washer was made in Searcy after Maytag bought Amana. The Norgetag's were made in Herrin, IL and some Atlantis (also a Norgetag) were made in Newton. Maytag management was not making wise decisions buying these other companies and taking their designs and integrating them into a "Maytag" washer. |
Post# 869549 , Reply# 20   2/28/2016 at 09:20 (2,979 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
