Thread Number: 64433
Stuck spanner nut -- Maytag LAT2600AAE |
Post# 870841 , Reply# 2   3/6/2016 at 13:20 (2,971 days old) by Askodude ()   |   | |
Can't you -carefully- heat it up with a torch? It helped removing a stuck pedal on a Shimano bike crank for me. |
Post# 870847 , Reply# 3   3/6/2016 at 14:27 (2,971 days old) by vacerator (Macomb, Michigan)   |   | |
Liquid wrench penetrating oil. W-D40 should also do it. Let it soak in a few days before heating it up. |
Post# 870848 , Reply# 4   3/6/2016 at 14:29 (2,971 days old) by rp2813 (Sannazay)   |   | |
Yeah, a blow torch/dryer will often help with freeing up stuck parts.
Others will have to confirm one way or another, but could the spanner nut have a reverse thread?
You might try punching applicable terms into the "Super Searchalator" option at the top right of the forum index page, below the regular search field, to see if there are any old threads with helpful information. |
Post# 870850 , Reply# 5   3/6/2016 at 14:36 (2,971 days old) by RoseRed ()   |   | |
@Askodude I don't have a torch and husband doesn't want me to spend any more money on the machine. I have to make do with what I have on hand. |
Post# 870863 , Reply# 7   3/6/2016 at 15:30 (2,971 days old) by appnut (TX)   |   | |
Post# 870864 , Reply# 8   3/6/2016 at 15:31 (2,971 days old) by rp2813 (Sannazay)   |   | |
Post# 870917 , Reply# 9   3/6/2016 at 22:22 (2,971 days old) by rp2813 (Sannazay)   |   | |
Post# 870931 , Reply# 10   3/7/2016 at 01:25 (2,970 days old) by nickatnight ()   |   | |
One of our local experts has confirmed you should be tapping your spanner wrench in the clock-wise direction, for this particular washer. |
Post# 870946 , Reply# 11   3/7/2016 at 04:40 (2,970 days old) by brucelucenta ()   |   | |
Post# 871005 , Reply# 13   3/7/2016 at 11:36 (2,970 days old) by DADoES (TX, U.S. of A.)   |   | |
Depends on if the extension cord is heavy enough for the length. I had trouble with running some Maytags (A206 and A608) via (too light of) an extension cord, the motor had trouble under load getting up to speed to drop out of the start winding. I'd expect PB more likely to help than a vinegar soak. |
Post# 871094 , Reply# 14   3/7/2016 at 18:51 (2,970 days old) by RoseRed ()   |   | |
@DADoES The appliance cord is 15 Amp/125 Volt. Would this be sufficient? |
Post# 873678 , Reply# 21   3/21/2016 at 13:36 (2,956 days old) by rp2813 (Sannazay)   |   | |
Post# 874508 , Reply# 23   3/26/2016 at 13:04 (2,951 days old) by tinkr (Phoenix Arizona)   |   | |
I have the same washer. The coasting to a stop after spinning... mine coasts to a stop. As for advancing while agitating opening the lid stops the machine, So I can't help you there.
This is a very durable machine 15 years old (approx) and very heavy use and still running fine. So fixing it will pay you back in years of service. I will be repairing mine if it gives up the ghost before I do. |
Post# 874512 , Reply# 24   3/26/2016 at 13:14 (2,951 days old) by rp2813 (Sannazay)   |   | |
Post# 874548 , Reply# 26   3/26/2016 at 23:21 (2,951 days old) by rp2813 (Sannazay)   |   | |
Post# 874594 , Reply# 27   3/27/2016 at 10:46 (2,950 days old) by tinkr (Phoenix Arizona)   |   | |
Post# 874623 , Reply# 28   3/27/2016 at 18:09 (2,950 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 874898 , Reply# 29   3/29/2016 at 20:21 (2,948 days old) by RoseRed ()   |   | |
@tinkr Thank you for taking the time to check on the spin/brake function of your washer. I'm really liking the wash/agitate action of this Maytag. |
Post# 875215 , Reply# 30   4/1/2016 at 08:24 (2,945 days old) by RoseRed ()   |   | |
How easily should the pump pulley spin/rotate? |
Post# 875247 , Reply# 31   4/1/2016 at 17:27 (2,945 days old) by goatfarmer (South Bend, home of Champions)   |   | |
