Thread Number: 64617
cleaning by using Citric acid & white vinegar Causing problems? |
Post# 872988   3/17/2016 at 10:05 (2,955 days old) by shim ()   |   | |
After I cleaning the washing machine by using Citric acid and then using white vinegar. The Drum coating was peeling or it's a hard calcium ? how i can rid from that ? |
Post# 873096 , Reply# 1   3/18/2016 at 00:57 (2,955 days old) by mark_wpduet (Lexington KY)   |   | |
Maybe because it's really hard to tell from the pics. I wonder what the outer tub looks like? Maybe make the room dark, shine a flashlight by putting the bulb of the light direction on the drum and look through the hole to see if you can see the outer tub? I can see my heating element in my duet doing this. I once wanted to see what my outer tub looked like and someone gave this tip. If you see buildup it might be from that? Maybe the first treatment was eating away at the buildup but wasn't able to get quite all of it?
My water is hard too, but laundry detergent has things in it to keep that from building up. Otherwise, I dunno. |
Post# 873110 , Reply# 2   3/18/2016 at 06:47 (2,955 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 873190 , Reply# 3   3/18/2016 at 16:07 (2,954 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 873274 , Reply# 4   3/18/2016 at 23:31 (2,954 days old) by kb0nes (Burnsville, MN)   |   | |
Post# 873344 , Reply# 6   3/19/2016 at 12:08 (2,953 days old) by kb0nes (Burnsville, MN)   |   | |
It looks as if the tub sat full of water for a long spell. If you can't rub/scratch it off with a thumb nail then it is just some sort of haze on the surface of the stainless.
You could polish it off with a little metal polish but that could be a lot of work. It won't hurt anything and using the washer will slowly polish it off. I'd say it isn't worth worrying about. |
Post# 873354 , Reply# 7   3/19/2016 at 14:01 (2,953 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 873355 , Reply# 8   3/19/2016 at 14:02 (2,953 days old) by shim ()   |   | |
thanks @ kb0nes if you can see picture No.7 i think it's (drum) going to be rusty, the washer machine still on warranty, Maybe I should ask fix it? |
Post# 873436 , Reply# 9   3/20/2016 at 03:36 (2,953 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 873448 , Reply# 10   3/20/2016 at 06:48 (2,953 days old) by shim ()   |   | |
@ mark_wpduet i dont know, but first, The pump was clogged, Then I did the cleaning. And I noticed that. it's strange , because I clean like that, all the time. I did cleaning at 90 degrees. And it's never happened before. |
Post# 873469 , Reply# 11   3/20/2016 at 10:00 (2,953 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
