Thread Number: 6466
out with the new |
Post# 130385   5/21/2006 at 14:52 (6,541 days old) by christfr (st louis mo)   |   | |
Post# 130386 , Reply# 1   5/21/2006 at 14:54 (6,541 days old) by christfr (st louis mo)   |   | |
Post# 130387 , Reply# 2   5/21/2006 at 14:57 (6,541 days old) by christfr (st louis mo)   |   | |
Post# 130424 , Reply# 3   5/21/2006 at 21:57 (6,541 days old) by frigilux (The Minnesota Prairie)   |   | |
Post# 130427 , Reply# 4   5/21/2006 at 22:06 (6,541 days old) by gadgetgary (Bristol,CT)   |   | |
Chris, Best of luck to you on your 'new' KitchenAid. I absolutely LOVE mine, and the fan assisted dry ROCKS! You can even buy those cheap 'throw-away' plastics in the KitchenAid. Cleaning is superior to many others, and, you cannot beat the porcelain tub. Mine was 14 yrs old in January and is still going strong. Again, nice transition~! |
Post# 130428 , Reply# 5   5/21/2006 at 22:10 (6,541 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 130444 , Reply# 6   5/21/2006 at 23:52 (6,541 days old) by johnb300m (Chicago)   |   | |
Post# 130464 , Reply# 8   5/22/2006 at 06:09 (6,541 days old) by christfr (st louis mo)   |   | |
i do test them in the garage first just have to change the inlet valve to one used in a portable machine that way it will take a reg hose. but this one passed the test with flying colors.. im guessin the white one must be at least 12 years old, the one i took out was 10. for what ever reason the one i took out likes to pee every once in a while and i dont know why never did oh well. but ill get rid of it on craigs list ,,,happy washing
Post# 130482 , Reply# 9   5/22/2006 at 07:56 (6,541 days old) by westyslantfront ()   |   | |
Hi Chris. I had KA with black front in my house in New York and would still have it if I had not moved West. Ross |
Post# 130484 , Reply# 10   5/22/2006 at 08:01 (6,541 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 130743 , Reply# 11   5/23/2006 at 06:06 (6,540 days old) by christfr (st louis mo)   |   | |
Post# 130744 , Reply# 12   5/23/2006 at 06:16 (6,540 days old) by gadgetgary (Bristol,CT)   |   | |
Post# 130899 , Reply# 14   5/23/2006 at 20:07 (6,539 days old) by peteski50 (New York)   |   | |
Post# 130978 , Reply# 15   5/24/2006 at 09:02 (6,539 days old) by deeptub (Carbondale, IL)   |   | |
southernmdgeguy: You'll need to clean out/replace the check valve in the drain line. It's the turquoise plastic part front-and-center behind the motor panel. The two halves of it unscrew from each other, and there is a rubber flapper inside it. If there is gunk on the seat the flap seals against, clean it off and you should be fine. If the flapper is deformed(curved)or broken off its rubber hinge, you'll need to replace the valve. I've actually never come across one where cleaning fixed it...they've all needed replacing. T. CLICK HERE TO GO TO deeptub's LINK |
