Thread Number: 64935
Whirlpool Duet Washer Problems |
Post# 875674 , Reply# 2   4/5/2016 at 07:47 (2,914 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
FH is a no water level switch trip error code. This can be caused by a few problems ^ as mentioned in the first reply. You might first check the water inlet screens to see if they're plugged, a fairly common problem. clean out the screens, flush the hoses and reconnect. If it's still giving you the error code and lines are clear, you may have to move on to checking the solenoid valve itself. |
