Thread Number: 65112
/ Tag: Classified Ad Finds
SEAFOAM GREEN - Vintage Frigidaire Refrigerator - $250 (pittsburg / antioch) |
Post# 877267   4/15/2016 at 23:08 (2,929 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Okay, too many of these are too far away.
Like like. CLICK HERE TO GO TO ovrphil's LINK on San Francisco Craigslist
Post# 877270 , Reply# 1   4/15/2016 at 23:14 (2,929 days old) by ovrphil (N.Atlanta / Georgia )   |   | |
Post# 877282 , Reply# 2   4/15/2016 at 23:47 (2,929 days old) by funktionalart (Rison, AR)   |   | |
Post# 877283 , Reply# 3   4/16/2016 at 00:27 (2,929 days old) by rp2813 (Sannazay)   |   | |
For sure. The copy hasn't changed since this ad first started running.
"Needs a professional to go through the system" tells me it's not in proper working order. I'd be very afraid it needs more than the simple tune-up the seller is suggesting.
It's a beautiful fridge. It either needs to be purchased by a "professional" who can make DIY repairs if necessary parts can be found, or it could become a prop somewhere. |
Post# 878194 , Reply# 4   4/22/2016 at 18:25 (2,922 days old) by StandingPilot (Cleveland)   |   | |
What are the dimensions of that 65? |
Post# 878201 , Reply# 5   4/22/2016 at 18:59 (2,922 days old) by funktionalart (Rison, AR)   |   | |
I have the '63 Frigidare model, basically the same as the one in that ad-- and I believe the cabinet is the same size--32" wide and a hair under 70" tall. I also have a '63 Coldspot Spacemaster 14, seen below. It is more along the size you'd want--64" tall and 32" wide.
There are a great deal of vintage out there made in the 64"-66" range. Happily, most are basically counter-depth, but I understand your snag with the cabinet/soffit limitations--I'm in the same boat! If you did decide to go modern/built-in, I believe the KitchenAid Superbas (Subzero look/build type) WILL fit the 83" limitation you have. I also cannot go with a unit any taller than 83", and I think the Superba is 82" (if I'm wrong on that, then it's the GE Monogram which fits--cannot recall exactly at the moment). I only can tell you I'm stuck with a SubZero which will not clear my soffits... |
Post# 878223 , Reply# 7   4/22/2016 at 20:45 (2,922 days old) by funktionalart (Rison, AR)   |   | |
I don't disagree with you on that--I personally do not buy or endorse new / non-US made stuff at all. However, I would have no issue with a modern/vintage early 90s KA unit which were still U.S. made. I come across them frequently, and mention them only as they were built manually controlled for the most part, come in the 36" width and can be paneled out in a way that will satisfy a vintage-look requirement...
