Thread Number: 65306
/ Tag: Classified Ad Finds
GE Filter-Flo Washer - $25 (Germantown, WI) |
Post# 879223   5/1/2016 at 15:06 (2,916 days old) by stricklybojack (South Hams Devon UK)   |   | |
Ad Copy: With intermittent water leak. These GE Filter-Flo's are known to be good for filtering out pet hair from clothes. We have a Filter-Flo washer that developed a water leak recently. The leak occurs only when the pump is emptying the washer's drum out into the utility tank. The water is coming from a rust hole in the outer tub. An appliance repair man from BB Washing Machine said that the inner tub has to be taken out so JB Weld can be applied to the outer tub to seal up the leak. Easy fix, in his opinion. Bonnie just wanted a new machine. The top panel reads "Heavy Duty Extra Large Capacity." It is a "Six cycle washer with mini-wash" It has a rotary switch to select from 3 different spin speeds. For water levels, it has the Mini-Basket setting and 4 more to choose from. There are 4 wash/rinse temperature combinations that are set with a rotary dial. The color is white and the exterior is in good condition. We have a small pickup truck and can deliver it if you aren't too far away. 4-14-531-76-76 Please avoid the texting. I'm too old for that and I have a flip phone from the Stone Age. CLICK HERE TO GO TO stricklybojack's LINK on Milwaukee Craigslist
