Thread Number: 65684
/ Tag: Wanted to Buy Items
is this a good deal and is it too vintage P 7 ? |
Post# 882603 , Reply# 1   5/29/2016 at 06:51 (2,880 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 882617 , Reply# 2   5/29/2016 at 07:50 (2,880 days old) by pulltostart (Mobile, AL)   |   | |
Post# 882621 , Reply# 3   5/29/2016 at 08:23 (2,880 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
I like the GE P-7 Range that I used to see in the ad, when General Electric first introduced the Self-Cleaning Oven...
My parents saved about 3/4 of a newspaper from Nov. 1963 when Pres. Kennedy was killed, and there's that almost full-page advertisement, complete with a "Mini-Oven" product demonstration at Hudson's...
Now that actual range, with the pushbuttons along each burner, the Sensi-Temp, Start & Stop Timer, Oven Thermometer, Light Switch on the Oven Door, and maybe even WITHOUT that 2nd Oven & Facade over the cooking surface--and in TURQUOISE!--...now THAT I want to see!!!!
-- Dave |
Post# 882685 , Reply# 5   5/29/2016 at 14:37 (2,880 days old) by pulltostart (Mobile, AL)   |   | |
The burners on this model should be the Tilt n Lock type, hard-wired, with removable trim rings and reflector pans. IF the Sensi-Temp burner is working properly it should also match this description. With the exception of the ST burner, replacements can be found online for burners that do not work and replacement is not difficult. The top does not lift up, it is a one-piece upswept porcelain top and cleaning the subtop must be done through the open burner ports (unless you want to disassemble the top from the range.
I was thinking this one says it is still connected so operation(s) could be verified by the buyer before purchase. Did I misread?
lawrence |
Post# 882686 , Reply# 6   5/29/2016 at 14:46 (2,880 days old) by pulltostart (Mobile, AL)   |   | |
The date code looks to be BZ, and that would indicated 1966. And regarding the price - what's it worth to you? If you are wanting a vintage range with the features that this one has and you are close enough to go get it, the asking isn't so unreasonable IMO. But there's nothing wrong with offering the seller less - if he/she wants to sell it badly enough I'm sure the price is negotiable.
lawrence |
Post# 882710 , Reply# 8   5/29/2016 at 17:40 (2,880 days old) by goatfarmer (South Bend, home of Champions)   |   | |
