Thread Number: 66840
Whirlpool Calypso - fix or part out |
Post# 895203 , Reply# 1   8/23/2016 at 05:44 (2,799 days old) by vacerator (Macomb, Michigan)   |   | |
like it's time for a new machine. It will take longer to rebuild than you have the time for. If you want to rebuild it in your spare time, parts and schematics are still online. |
Post# 895324 , Reply# 4   8/23/2016 at 15:48 (2,799 days old) by DADoES (TX, U.S. of A.)   |   | |
Rusting is the bane of Calypsos. I found one used 9 years ago that was in good condition in that regard, although it needed a new u-joint, basket, and some scrubbing. Collected a stash of spare parts along the way. The touch panel went wonky last year, and replaced the pump for getting a bit noisy. The boards, (working) touch panel, lid switch, water valve assembly and hoses, dispensers, water level pressure switch(es), motor, and pump (condition?) could be useful to someone. Maybe the lid depending on condition. Other mechanical parts require increasing levels of disassembly to access and would be suspect for condition. |
Post# 895329 , Reply# 5   8/23/2016 at 16:14 (2,799 days old) by Yogitunes (New Jersey)   |   | |
Post# 895577 , Reply# 8   8/24/2016 at 19:43 (2,798 days old) by Yogitunes (New Jersey)   |   | |
