Thread Number: 67
Kitchenaid KDC 14 |
Post# 44923 , Reply# 1   9/12/2004 at 00:29 (7,158 days old) by Unimatic1140 (Minneapolis)   |   | |
Hi Steve, that's a beauty you have there. The fill valve is easily replaced with any standard KitchenAid replacement valve. The rust I wouldn't worry about, exposed cast iron rusts normally. You should also be able to take apart the drain valve and clean it, if that doesn't help I bet you can get a generic KitchenAid drain valve for the later models that should work just fine in this machine.
Post# 44929 , Reply# 2   9/12/2004 at 05:13 (7,158 days old) by partycycle ()   |   | |
Steve thanks for posting those terrific KA pictures again. I didn’t know how to go back since website upgrade. Listen to Robert he knows. You both have fantastic beloved KA’s. Your kitchens will be fabulous!!! |
Post# 44933 , Reply# 3   9/12/2004 at 08:40 (7,158 days old) by christfr (st louis mo)   |   | |
Post# 44951 , Reply# 4   9/12/2004 at 20:04 (7,157 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Woweee what a find hold onto it! They clean like nothing else! Steve don't worry about the drip from the cast iron drain valve. As you use it, it will seal up on its own and not drip, mine took about a month before it sealed right up. You have to be careful with that drain valve the original early ones were designed to be taken apart and fixed but the later ones have a grooving on the valve stem that if you take it apart will cause the valve to continually leak upon reassembly. I wouldn't touch it if it works, I'll scan the section on the valve and send it to you as a pdf. Ohh don't you just love the "clunk to clean" feature??!! I do! cheers jon |
Post# 44952 , Reply# 5   9/12/2004 at 20:15 (7,157 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 45894 , Reply# 7   9/27/2004 at 14:32 (7,143 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
