Thread Number: 67086
Kenmore 90 Series washer |
Post# 897891 , Reply# 1   9/9/2016 at 10:19 (2,756 days old) by Yogitunes (New Jersey)   |   | |
Post# 897894 , Reply# 2   9/9/2016 at 10:34 (2,756 days old) by Sheryl (Oklahoma)   |   | |
Like places that oil or grease goes in. I'm forgetting the correct word for it right now. Like where you might use a grease gun |
Post# 897896 , Reply# 3   9/9/2016 at 10:36 (2,756 days old) by murando531 (Augusta, Georgia - US)   |   | |
As far as I know, on DirectDrive Whirlpool built machines like yours, the transmissions are permanently sealed systems that shouldn't need oil replacements or refills during their lifetime. The motor coupler that you replaced is typically the most common part to go bad, which is a good thing, because it absorbs some of the daily wear and impact between the transmission and motor. So long as your machine is agitating and neutral draining/spinning properly and there is no odd noise or smell or oil on the floor, you should be right as rain! Hope that helps. :)
Post# 897899 , Reply# 4   9/9/2016 at 10:54 (2,756 days old) by DADoES (TX, U.S. of A.)   |   | |
