Thread Number: 67380
Insanity Whirlpool Pressure Switch WPW10415587 $112!@!@!@ |
Post# 901021 , Reply# 1   9/29/2016 at 15:11 (2,736 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Your washer started working again, but be aware, if it happened once, it will most likely happen again, so be prepared.
My first KM He5t did that the first time I plugged it in and never was able to do laundry in it. Turns out it had a host of other issues and Kenmore replaced it with another machine 2 weeks later. This machine (the replacement) worked flawlessly for about 4 years when that familiar and dreaded "F35" error code appeared on the display. I replaced the water level / pressure switch and it's working flawlessly again.
The link below is for the part on Amazon ($80).
Good luck! Kevin
CLICK HERE TO GO TO RevvinKevin's LINK |
Post# 901604 , Reply# 3   10/3/2016 at 11:04 (2,732 days old) by glomain (tuscarawas cnty. (eastern ohio))   |   | |
the same problem,called a local parts place,he said they are know for this,he said take the hose off the pressure switch blow threw it (known to clog where it connects to tub) reconnect & try it. I did & it took care of the problem.other wise the pressure switch was 49.99 plus tax(which I didnt need)
Post# 901763 , Reply# 5   10/4/2016 at 14:19 (2,731 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
I also live alone (with my dog), though that will change in the next couple months. Anyway... I can easily do 4 loads at the same time and being I do 4 to 5 loads every 2 weeks, it's really great NOT having to spend all day doing laundry (just 2 hours to wash & dry).
Kevin
Post# 901817 , Reply# 6   10/5/2016 at 00:18 (2,731 days old) by MattL (Flushing, MI)   |   | |
Wow. what a great assortment. Looks like fun. |
