Thread Number: 68173
Washer makes gurgling noise without suds |
Post# 908948 , Reply# 1   11/29/2016 at 03:27 (2,677 days old) by qualin (Canada)   |   | |
Please take a picture of your drain hose and drain setup and post it to this thread so that I can see if there's anything obvious. Maybe there isn't... I always thought that drain hose gurgling was normal... |
Post# 908983 , Reply# 3   11/29/2016 at 08:51 (2,676 days old) by Yogitunes (New Jersey)   |   | |
that's just pump cavitation....high suds levels just muffles it...
most likely sounds louder when the hose is placed in a stand pipe, the echo effect... a common thing with machines where the pump to hose is a direct run.... most times a loop of some sort in the drain line will eliminate that noise.... some machines use a flapper valve to prevent air/water being sucked back into the machine, which creates that noise |
Post# 908992 , Reply# 4   11/29/2016 at 11:39 (2,676 days old) by mrb627 (Buford, GA)   |   | |
