You can remove the back cover from the console and look on the back of the water level control--Is there an adjustment screw on the back of it-you should be able to use that to adjust the water level.I have found some washers I got the water level was too low.If it has the adjustment you can set the level to what you want.That the expereince I had with WP-KN washers.If you open the console-just remember to unplug the machine in between adjustments to prevent shock.
