Thread Number: 68754
/ Tag: Modern Dishwashers
Whirlpool Dishwasher problem |
Post# 915610 , Reply# 1   1/14/2017 at 10:09 (2,652 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Does it drain through an air gap? If it does not, no problem. If it does, the tubes can clog. If no water is getting out, it would be the inner one.
Is the motor reversing to drain? |
Post# 915820 , Reply# 3   1/15/2017 at 17:52 (2,651 days old) by imperial70 (MA USA)   |   | |
by the disposer connector. The hose used was what looks like the old style non-corrugated rubber hose. Thank you for the great advise. I was worried it was going to be something more tragic. |
Post# 915968 , Reply# 4   1/16/2017 at 19:24 (2,650 days old) by Tomturbomatic (Beltsville, MD)   |   | |
I wonder what she put down the disposer to cause that kind of torsion. |
Post# 915975 , Reply# 5   1/16/2017 at 21:17 (2,650 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
If the pump and motor run fine in the drain direction and it does not have a clogged air-gap or badly kinked rubber drain hose, then remove the drain hose from the check valve that is screwed into the pump assembly. If water does not poor out unscrew the DCV and you will likley find that has something loged in it, unclog it and the DW will will work fine again.
Note: when you unscrew the DCV any water in the DW will poor out, be prepared to catch or mop up about 2 gallons of water. |
