Thread Number: 69026
Blond question for the experts |
Post# 918131   1/29/2017 at 17:31 (2,615 days old) by bajaespuma (Connecticut)   |   | |
How exactly does a "wax motor" work? I realize they're relatively new components that do small jobs like dispensing stuff but I'm curious about how they work and why are they called "wax" motors? Are they actually made out of wax?
Post# 918133 , Reply# 1   1/29/2017 at 17:43 (2,615 days old) by DADoES (TX, U.S. of A.)   |   | |
I've not disassembled one but my understanding is that, yes, a thermal-sensitive wax compound is involved. It's in a sealed chamber with the spring-loaded actuating piston at one end and a small heat source at the other. The wax expands when heated to move the piston. Cools and contracts when the heat is stopped and the spring helps compress it to retract the piston. Perhaps someone more knowledgeable can clarify and correct any errors in that description. |
Post# 918135 , Reply# 2   1/29/2017 at 18:08 (2,615 days old) by kb0nes (Burnsville, MN)   |   | |
Post# 918210 , Reply# 3   1/30/2017 at 05:29 (2,614 days old) by akronman (Akron/Cleveland Ohio)   |   | |
While these are rarely used in appliances in the home, think of how much easier they'd be than typical water valve electromagnetic solenoids, for the plumbing and hoses. Electromagnetics switch on and off in a microsecond, creating pressure and strain on the plumbing and hoses. These would be slower acting, less damaging.
They have plenty of automobile and avionics uses, but have rarely been applied to domestic appliances. |
Post# 918258 , Reply# 4   1/30/2017 at 12:00 (2,614 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Have been used by the millions over the last 25 years in dishwashers, washing machines and front load washers door locks etc.
They would not be suitable for an inlet valve as they close to slowly they can take up to one minute to close after the power is disconnected from them.
Almost all US-made inlet valves went to a slow close design back in the 1970s, this illuminated the water hammer and strain on pipes when the valves close. |
Post# 918259 , Reply# 5   1/30/2017 at 12:17 (2,614 days old) by bajaespuma (Connecticut)   |   | |
Post# 918701 , Reply# 6   2/1/2017 at 22:18 (2,612 days old) by askolover (South of Nash Vegas, TN)   |   | |
