Thread Number: 6909
Another KitchenAid Story
Post# 137119   6/21/2006 at 16:01 (6,508 days old) by jakins (Kissimmee, Fl.)
jakins's profile picture
Hi All
the KD-20 got here a few weeks ago and has been a lot of fun, and a few grey hairs to play with. First I found that the fan for the drying system dod not work. Not to worry we have a store here in central Florida that recyclec old electracal and electronic parts called Skycraft. they had a fan motor that I used to fix that problem. the main Problem I had was the drain for this dishwasher. I tried two diff. Pumps that have worked for me in the past, No Good the timer did not give them enough time to drain. I was rincing with soapy water. This dishwasher has a gravity drain and is installed in Fl. where we have no cellars, and is on my back porch just below grade. What to Do? I plumbed the gravity drain to the back of the cabinet cut holes so the pipe went under and out of site and hooked into a narrow bucket equiped with a sump pump and float switch. PROBLEM SLOVED. She works fine and the sump has wide enough openings to pump out any food particals that may pass the filter in the machine. The only way that I can use this machine is this way. Now since I can only use this machine as a built in in this house, I have Two side panels and a porcelain top to make a stand alone unit of you kitchenaid. They may work with a kd-11, kd-12,
kd-14 I am not sure about that but may be worth a try. the panels are yours for the asking, You pay the shipping and they are yours.
Thanks
John
Post# 137120 , Reply# 1   6/21/2006 at 16:02 (6,508 days old) by jakins (Kissimmee, Fl.)
Before
From Craigs list
Post# 137121 , Reply# 2   6/21/2006 at 16:03 (6,508 days old) by jakins (Kissimmee, Fl.)
befor inside
inside
Post# 137122 , Reply# 3   6/21/2006 at 16:04 (6,508 days old) by jakins (Kissimmee, Fl.)
drain
drain
Post# 137123 , Reply# 4   6/21/2006 at 16:05 (6,508 days old) by jakins (Kissimmee, Fl.)
pump
pump
Post# 137125 , Reply# 5   6/21/2006 at 16:06 (6,508 days old) by unimatic1140 (Minneapolis)
John that is just beautiful and I know what its like to have to try 10,000 things to get a machine to work just right.
When you have a chance I would love to see the dial close up as well as an interior shot of those stainless steel racks!
Post# 137126 , Reply# 6   6/21/2006 at 16:06 (6,508 days old) by jakins (Kissimmee, Fl.)
closed
closed
Post# 137127 , Reply# 7   6/21/2006 at 16:08 (6,508 days old) by jakins (Kissimmee, Fl.)
open
open
Post# 137128 , Reply# 8   6/21/2006 at 16:09 (6,508 days old) by jakins (Kissimmee, Fl.)
Dial and racks
Comming Right Up!!
Post# 137133 , Reply# 9   6/21/2006 at 16:20 (6,508 days old) by jakins (Kissimmee, Fl.)
Racks
The racks need a little brucsing yet but look 100% better after a wash with detergent.
Post# 137134 , Reply# 10   6/21/2006 at 16:21 (6,508 days old) by jakins (Kissimmee, Fl.)
Dial
Dial 1
Post# 137135 , Reply# 11   6/21/2006 at 16:21 (6,508 days old) by jakins (Kissimmee, Fl.)
Dial 2
dial
Post# 137136 , Reply# 12   6/21/2006 at 16:22 (6,508 days old) by jakins (Kissimmee, Fl.)
tag
tag
Post# 137138 , Reply# 13   6/21/2006 at 16:25 (6,508 days old) by jakins (Kissimmee, Fl.)
Painting the Spray Arm
Have any of you guys had to do this. I was thinking an easy way would be to use swimming pool paint as it is made to stand up to harsh chemicals and water. Any thoughts
John
Post# 137140 , Reply# 14   6/21/2006 at 16:31 (6,508 days old) by gregm ()
try ..........
John, for what its worth, I wire brushed my spray arm then sanded with coarse and then finer but not very fine sandpaper and brush painted it grey with rustoleum and have used the machine many, many times with no problem whatsoever. Maybe a "marine" paint would work well too or any "epoxy" type paint, I believe the true color of your spray arm should be black and you could use a "spray-epoxy-appliance" paint made by rustoleum and found at home depot. Maybe others might have better suggestions. Your machine is STUNNING, I absolutely LOVE IT !!!!! I wish they had made the metal racks longer, I think they only did that for a small # of years, plus the silver dial and pushbutton vs the later plastic ones, wow, I just love it, good for you :)
Post# 137145 , Reply# 15   6/21/2006 at 16:55 (6,508 days old) by gansky1 (Omaha, The Home of the TV Dinner!)
gansky1's profile picture
Beautiful dishwasher!!!!!
Great idea for the drain system too, it would be a shame to have to not use the machine for that pesky little reason.
Post# 137151 , Reply# 16   6/21/2006 at 17:57 (6,508 days old) by pdub (Portland, Oregon)
pdub's profile picture
John-
That is one beautiful KitchenAid and it looks very good
with your sink and cabinets as a built in. have fun!
Patrick
Post# 137161 , Reply# 17   6/21/2006 at 19:15 (6,508 days old) by jamman_98 (Columbia, SC)
Question
jamman_98's profile picture
Ok I got earlier this month a KD-12 model. Am I going to have the same drain problem when I eventually hook it up? My spray arm has a small amount of rust so I would love to hear what to do about that too. Jakins beautiful machine you got there!
Thanks
Joe
jamman_98
Post# 137174 , Reply# 18   6/21/2006 at 20:52 (6,508 days old) by frigilux (The Minnesota Prairie)
frigilux's profile picture
Great looking machine! Goes well with your Westy Laundro, too.
Question: How long is the cycle on this KA?
Post# 137176 , Reply# 19   6/21/2006 at 20:59 (6,508 days old) by quiltnbear ()
Oh my god I see a Westy
I love your dishwasher too, but that Westy I want one so bad!! Anyway congrats on that great dish machine. Scott in CA
Post# 137179 , Reply# 20   6/21/2006 at 21:05 (6,508 days old) by gansky1 (Omaha, The Home of the TV Dinner!)
I keep staring at it...
I love the stainless steel racks and that dial looks like it weighs 10 pounds!
Post# 137186 , Reply# 21   6/21/2006 at 21:36 (6,508 days old) by mayken4now (Panama City, Florida)
mayken4now's profile picture
the machine you have is out of this world for cleaning ability. thanks for all the wonderful photos
Post# 137197 , Reply# 22   6/21/2006 at 22:15 (6,508 days old) by tlee618 ()
John what a beautiful machine. I love those racks. Just wonder how long the cycle takes to complete? Beautiful Westinghouse next to it as well!! Do you use it often? Terry
Post# 137208 , Reply# 23   6/21/2006 at 22:47 (6,508 days old) by gregm ()
cycle time
I think the cycle averages 20-30 min ........... does this have forced air drying or is it "before" that ? I think it has one long 5 or maybe a tad longer minute wash, and two-two minute rinses and a ten or maybe 15 min dry period.
Post# 137210 , Reply# 24   6/21/2006 at 22:57 (6,508 days old) by frigilux (The Minnesota Prairie)
Thanks for the cycle time info, Greg. Half-an-hour. That's amazing. My new Maytag takes nearly two hours in its Normal cycle, even without the water-heat option.
Post# 137246 , Reply# 25   6/22/2006 at 09:14 (6,508 days old) by tlee618 ()
Yes, thanks for the information Greg, I think all dishwashers should have a cycle choice that could be completed in that amount of time. Eugene, 2 hours sure seems like a long time!! Hope you are never in a hurry for those dishes.LOL Terry
Post# 137263 , Reply# 26   6/22/2006 at 10:09 (6,508 days old) by tomturbomatic (Beltsville, MD)
Great machine. Congratulations. I don't understand about the drain pump. Did you try washing machine pumps? I imagine that you can still get the pump used in the Kenmore Dual Tumble washer which was the last year of the old Westinghouse design with European modifications by Electrolux. It featured a very powerful pump with a strong motor. It should not be too hard to wire the pump motor in series with the drain valve since you have already tried other pumps.
The two part epoxy paint should prove very durable for the wash arm. Duron makes several colors. I have seen other epoxy paint kits at Home Depot near where they sell sinks because you can use it it to paint tubs, etc.
Post# 137284 , Reply# 27   6/22/2006 at 11:07 (6,508 days old) by chachp (North Little Rock, AR)
John,
chachp's profile picture
I know someone who had their wash arm redone. I have sent him an email for the information. I didn't want to post his informaion without asking but I remember his looked really nice when it was redone.
Post# 137292 , Reply# 28   6/22/2006 at 12:31 (6,508 days old) by frigilux (The Minnesota Prairie)
Terry-- I have found that using the INSTA WASH cycle (which is only 20 minutes long, with no drying period) cleans many of my loads very well. Obviously I don't wash unscrubbed pots/pans or BobLoads® using that cycle, but it drives me insane to wait 1-1/2 hours (I generally interrupt and cancel the dry portion of the cycle) for loads washed on the NORMAL cycle.
The way I cook, there are generally two loads of pots/pans, etc. during food prep, then a BobLoad® of dinner dishes and a final load of dessert dishes and renegade pots/pans.
My previous DW, a TOL Frigidaire had an EXPRESS cycle, which was 35 minutes (again, subtracting the dry portion) and I used it almost all the time with great results. The Maytag's INSTA WASH is just a little too short to handle the loads the short cycle on my Frigi could handle.
Having said that, the new Maytag cleans pots/pans/casseroles much better than the Frigidaire ever did. Six of one, half a dozen of the other....
Post# 137303 , Reply# 29   6/22/2006 at 13:30 (6,508 days old) by tlee618 ()
Hi Eugene, That makes sense that it would have the Ista Cycle. I can understand your flustration with that long long cycle just for a normal load. Thanks for the information. Terry
Post# 137344 , Reply# 30   6/22/2006 at 18:37 (6,507 days old) by appnut (TX)
appnut's profile picture
Eugene, what about using the light cycle instead of normal?
Post# 137347 , Reply# 31   6/22/2006 at 18:50 (6,507 days old) by gadgetgary (Bristol,CT)
TOL Frigidaire
gadgetgary's profile picture
Eugene,
Ahem......Pics????
Post# 137355 , Reply# 32   6/22/2006 at 19:16 (6,507 days old) by mikepaquette ()
Frigilux
With that many dirty dishes I sure wish I had a invite for a meal. I just know your a good cook !!! Mike
Post# 137369 , Reply# 33   6/22/2006 at 21:10 (6,507 days old) by frigilux (The Minnesota Prairie)
GadgetGary-- I wish I had some pics of the Frigidaire, but I don't. It is in my sister's home. I gave it to her when I bought my new Maytag back in December.
Mike-- Yes, meals at my house are pretty damn good if I may say so. I have a full-time buffet (with skirting and the whole nine yards) set up in my dining room. I used to work for a catering business, so I have a lot of equipment and dishes. I live in a very small town and having people over for dinner/brunch a few times during the week constitutes my social life. We have a lot of fun and everyone enjoys the food and company. I'd love to have everyone from AW.ORG over, but my only washer is a 2003 Frigidaire FL'er. I like it, but it's boring and not vintage.
Bob-- Actually, there is no LIGHT cycle on this model. It has HEAVY, NORMAL, CHINA/CRYSTAL and INSTA-WASH cycles. To be honest, I've never once used the CHINA cycle on any of my DW's. Don't know why, I just never have. Maybe I should try that. I'll time it and see how long it is. BTW, in your honor, I refuse to use the term BobLoad® without the registered trademark symbol. Even if it is illegal. You've earned it, man!
Post# 137375 , Reply# 34   6/22/2006 at 21:28 (6,507 days old) by gadgetgary (Bristol,CT)
How 'bout pics of your current dishwasher...panel, top rack, bottom rack...etc????
Dirty dishes and all.
Post# 137385 , Reply# 35   6/22/2006 at 21:49 (6,507 days old) by appnut (TX)
Gary, looks like you missed all the pix Eugene posted of his new dishwasher, at the time, and I do believe he may have had a load or two. But now I hope he shows us many more examples. Eugene, the owner manuals online for your dishwasher use the term light. I believe it's the same as your china/crystal cycle. 1 wash/2 rinses and a time of 82 minutes, that 45 mins. longer than the insta wash, and has the same cycle sequence, but with water heating. You can add high-temp wash option as well as tough scrub (plus?) options even to this cycle. Give it a whirl.
On many of today's dishwasher, china/crystal is a euphamism for light wash cycle.
Post# 137470 , Reply# 36   6/23/2006 at 08:18 (6,507 days old) by chachp (North Little Rock, AR)
Here is his reply on the wash arm..
"I had my wash arm powder coated and made sure they covered the machined bore and shoulder on the underside. It still looks new. However, the white powdercoating I had done to the inside door panel has peeled off in huge sheets. Very disappointing."
Hope that helps!
Post# 137584 , Reply# 37   6/23/2006 at 20:08 (6,506 days old) by gansky1 (Omaha, The Home of the TV Dinner!)
John, would you mind, when you have a chance, to photo the sump/screen area? It looks very different than later models. This 10 series is so cool!
Post# 137698 , Reply# 38   6/24/2006 at 11:34 (6,506 days old) by westytoploader ()
John,
LOVE that vintage KitchenAid, those early machines are absolutely stunning!!! Very deco styling if you ask me, and those SS racks make it even better! I bet it just blasts through the dirt...just shows that a long cycle isn't needed to clean well!
Congrats and thanks for posting!
--Austin
Post# 137792 , Reply# 39   6/25/2006 at 00:20 (6,505 days old) by todde ()
Kitchenaid promotion contest
On the kitchenaid site, and go under promotions they ran a contest on who had the oldest kitchaid model dishwasher. Winner was a KD10 from 1950 in a Frank Lloyd Wright house, and thye show some other runners up. Winner won $15,000 in KA appliances. I'm not good at linking to websites, maybe someone else can provide the link.
Post# 137808 , Reply# 40   6/25/2006 at 05:36 (6,505 days old) by gadgetgary (Bristol,CT)
KitchenAid winners
Post# 137818 , Reply# 41   6/25/2006 at 07:39 (6,505 days old) by toggleswitch (New York City, NY)
I an not generally an alarmist, however............
toggleswitch's profile picture
People:
Beware of what you use in a DW-
My father recants horror stories of DOCTORS with which he worked that used an aquarium sealant (assuming it was non-toxic to life) that eventually leached into the DW and caused PERMANENT, IRREVERSIBLE neurological damage to the doctor's family. Sadly they were a bunch of extra-bright intellectually gifted people. Not after the damage was done.
PLEASE PLEASE PLEASE ensure all lubricants, paints, caulking etc is fit for use as you intended to use it.
Remember: would you put the substance on a plate and eat it? Because that is, in effect, what you are doing.
Best of luck! Looks like an AWESOME machine.
Post# 137829 , Reply# 42   6/25/2006 at 09:51 (6,505 days old) by jakins (Kissimmee, Fl.)
Sump Pics
Here are the pics as requested. that Is not rust the finish is wearing off and the screen is brass.
Post# 137830 , Reply# 43   6/25/2006 at 09:51 (6,505 days old) by jakins (Kissimmee, Fl.)
drain cover insert bakalite
drain
Post# 137831 , Reply# 44   6/25/2006 at 09:52 (6,505 days old) by jakins (Kissimmee, Fl.)
sump
sump
Post# 137832 , Reply# 45   6/25/2006 at 09:53 (6,505 days old) by jakins (Kissimmee, Fl.)
pump head
pump head
Post# 137833 , Reply# 46   6/25/2006 at 09:54 (6,505 days old) by jakins (Kissimmee, Fl.)
Sump dimentions
the sump is 10" wide 10" long and 6" deep
Post# 137844 , Reply# 47   6/25/2006 at 11:13 (6,505 days old) by tlee618 ()
Thanks so much Todd and Gary, that was so interesting. Funny to because Greg and I were just talking about that contest this past week and wondering who had won. Terry
Post# 137852 , Reply# 48   6/25/2006 at 11:41 (6,505 days old) by tomturbomatic (Beltsville, MD)
poisoned by the dishwasher
Toggle, I don't understand how a silicone sealer made for aquariums would have anything to leach into the water that would render people idiots. The non-aquarium silicones have arsenic, I think, to inhibit mold growth, but if anything was going to leach into the water that would damage people neurologically, just from the minute amount that would be a trace film on the dried dishes, it would quickly kill fish that lived in the tank of water into which it was leaching. What did they find in the hair samples of the sealant victims? How long did it take after the dw repair for the family to exhibit symptoms? Was it just the doctor's family and not the doctor who had neurological damage? That would be strange unless the doctor was poisoning his family. Are you sure that this was not more of a Love Canal thing than dishwasher repair? If this was caused by the sealant, why were there not warnings about a very widely used product? The neurological symptoms you describe sound more like the effects of mercury or lead or one of the other heavy metals. Lead has been banned from solder for a long time, but could have leached from the pipes in an older house. Were the kids and mother all poisoned? Were the kids doing drugs? Were they using dishes with lead or cadmium in the glaze? Worse yet, were they mixing and storing KoolAid & citrus drinks in a metalic container or in a ceramic pitcher with a lead or cadmium glaze that was leaching into the acidic solution? Washing ceramic ware with a poor glaze that contained lead or cadmium in the dishwasher would certainly damage the glaze to where it would leach far faster into food and drink. Did they keep wine or liquor in lead crystal decanters? Lead leaches into those liquids very quickly. Something about this story does not add up. I respect the necessity to guard ourselves from contaminents and I respect you and I know that you would not knowingly relate something as the truth that you knew was false when you know we would slash you, our dear friend Toggle, to shreds within seconds of discovering the truth, but I think we have more in this dishwasher sealant story than aquarium sealer.
Post# 137879 , Reply# 49   6/25/2006 at 12:51 (6,505 days old) by toggleswitch (New York City, NY)
All information must be taken and judged against its source.
I can only offer a caveat.
Doc used the sealant in question to hold in place and mend a gasket, rather than spend a few rupies on a new one. My father showed me the newspaper article and told me he knew the doctor after having personally designed his laboratory for him. (Dad was an architect by trade.) The doctor was a research scientist for a non-rpofit organization (Translation: VERY low pay.)
My conscious is clear. I said what I thought was prudent.
If my statement is ridiculous, then so be it.
I am not trying to hurt anyone or pee in anyone's Cheerios.
(But I somehow always manage).
Post# 137936 , Reply# 50   6/25/2006 at 21:18 (6,504 days old) by veg-o-matic (Baltimore, Hon!)
veg-o-matic's profile picture
Now see, I always cook my aquarium sealant in a Club Aluminum pot before I use it in the dishwasher. I think it gets rid of all the "bad stuff."
And I'm no stupider than the next guy...
veg
Post# 137937 , Reply# 51   6/25/2006 at 21:23 (6,504 days old) by toggleswitch (New York City, NY)
The finger is unintentional
It is not directed at anyone. but it IS kinda funny).
