Thread Number: 69229
New AEG UK |
Post# 920536   2/10/2017 at 16:02 (2,602 days old) by Paulinroyton (B)   |   | |
AEG www.aeg.co.uk/laundry/laundry/was... |
Post# 920553 , Reply# 1   2/10/2017 at 17:10 (2,602 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Looking very slick, its not totally unique, you can see vestel cabinets / pump housing , Siemens dooresque and mashup of beko /boschette/grundig fascia...Like it !!
Specification: 9kg Load, 1600rpm - 44%residual moisture Internal light for optimal visibility in the washing machine Time saving options Antiflood device with Aqua Control sensor Jet system washing technology Handwash programme / wool programme: An extremely gentle programme that allows 'handwash' labelled or wool items to be washed by machine. Delay start option - set the machine to start when it suits you Wool plus programme: The only wool programme in the market with a cool down at the end of the wash phase preventing chill-shock when the cold rinse begins, ensuring shrinkage is minimised. Steam programmes: Special steam programmes to make ironing easier and to remove odours and creases Synthetics programmes Anti-flood protection A+++ energy efficiency class This labelling scheme is designed to offer a standardised method of choosing the most energy efficient appliances. In addition to energy efficiency, the label also gives similar ratings for spin drying performance ('A' - most efficient, 'G' - least efficient). This washing machine is rated 'A' class for spin drying performance. The best standard of spin drying you can get. Child safety lock: Keypads can be locked to ensure temperatures and programme selectors can not be changed - making certain your laundry is always safe. Delay start option: Set the programme to begin at a time convenient to you LogiControl™ touch display Anti-allergy programme: Ensures the temperature is constantly maintained above 60°C by repeatedly re-heating during the wash phase resulting in exceptional hygiene and the complete removal of various allergens. Programmes include: Interior light: The interior light automatically lights up when door is opened for greater visability when loading and unloading. Time save option: Reduce wash cycle times by up to 60% with Time Saver. Perfect for lightly soiled clothes that you need in a hurry. Options include: Aqua Control: Aqua Control is an internal system which monitors the water level to detect water leakage. Delicate programme: The delicate programme gently washes the most delicate of fabrics. LED display Out of balance control of the drum load Pre-wash option Large capacity: In our large capacity washer you can wash larger loads saving you time & effort. Fuzzy Logic technology, adapting to the load Child lock A class wash performance: This labelling scheme is designed to offer a standardised method of choosing the most energy efficient appliances. In addition to energy efficiency, the label also gives similar ratings for washing performance ('A' - most efficient, 'G' - least efficient). This model is rated 'A' class for washing performance. The highest level of wash performance you can get. Ultra quick wash: This quick wash is a complete programme that allows you to wash upto 3kgs at 30°C in just 20 minutes! Making washing small loads efficiently easier than ever before. Cottons programmes: Includes regular cottons and cotton economy programmes. Stain action option: The stain action function allows you to use stain removing agents in a specific fourth compartment within the detergent drawer. Performance Load Capacity kg (Wash): 9 Display type: Big LED Motor system: Permanent Magnet Energy cons. Std. Cotton 60°C (kWh): 0.32 Energy cons. Std. Cotton 60°C, half load (kWh): 0.3 Energy cons. Std. Cotton 40°C, half load (kWh): 0.3 Front door: P1B + Turbine Time of wash / cotton 60°C: 268 Progr. time Std. Cotton 60°C, half load (min): 247 Progr. time Std. Cotton 40°C, half load (min): 234 Installation Colour: White Height (mm): 850 Width (mm): 600 DepthMax: 639 Water Supply: Cold Gross weight (kg): 82 Net Weight: 80.5 Energy Energy Class: A+++ Energy cons. annual (kWh) (2010/30/EC): 76,0 Spin drying efficiency (2010/30/EC): A Max. spin speed (rpm) (2010/30/EC): 1600 Water cons. annual (l) (2010/30/EC): 10499 Off mode power cons. (W) (2010/30/EC): 0,30 Left-on mode power cons. (W) (2010/30/EC): 0,30 Moisture % after max. spin (2010/30/EC): 44 Declared programme (2010/30/EC): Std cotton 60 half & full load,Std cotton 40 half load Left-on mode duration (min) (2010/30/EC): 5 Washing noise (dB(A) re 1 pW) (2010/30/EC): 47 Spinning noise (dB(A) re 1 pW) (2010/30/EC): 75 |
Post# 920555 , Reply# 2   2/10/2017 at 17:18 (2,602 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
5. THE WATER SOFTENER (SOFTWATER TECHNOLOGY)
5.1 Introduction The water contains harsh minerals. The higher the content of these minerals the harder the water is. Hard water can reduce the effectiveness of the detergent, reduce the softness of fabrics and contribute towards shrinkage and colour fading. This appliance is equipped with a water softener able to provide the right degree of water softening to preserve the fabric integrity, colour brightness and ensuring good wash performances at low temperature. The water softener should be adjusted according to the water hardness of your inlet water. A correct setting allows to achieve the best washing results and the maximum garments protection. To set the water softener correctly, please refer to 'How to set the water hardness level'. 5.2 How to set the water hardness level The appliance allows you to chose between 7 levels corresponding to 7 different ranges of water hardness. Depending on the country, the water hardness is expressed in equivalent scales: e.g. French degrees (°f), German degrees (°d), English degrees (°e) and mmol/l. If necessary, please contact your local water authority to check the water hardness in your area. Check in the "Water hardness levels" table which is the proper level. To set the water hardness level: 1. Press the On/Off button for a few seconds to activate the appliance. 2. Wait about 10 seconds for appliance internal check. 3. Touch the Stains/Prewash and the Plus Steam buttons simultaneously (by touching the two buttons at the same instant, as shown in the next drawing) for some seconds until the display shows the default level C04 and the indicator goes on. It means the water softener is active during washing only. |
Post# 920575 , Reply# 3   2/10/2017 at 19:00 (2,602 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 920587 , Reply# 4   2/10/2017 at 19:48 (2,602 days old) by Logixx (Germany)   |   | |
That's for the Eco wash cycle. Basically, you are supposed to pack the drum until you have to force the door shut and then the clothes will be washed in (energy-saving) 80F water long enough to achieve the same cleaning as a normal 140F Cotton cycle. It's all marketing so manufacturers can show off how energy efficient their appliance is, while still achieving the required A class cleaning performance.
All the other cycles actually heat to the selected temp and run faster - of course sacrificing energy efficiency in return. A recent survey by our consumer magazine showed that people do look for super efficient machines... but once they get them home and see the cycle time, they don't use the Eco cycle - negating the energy savings they initially bought the washer for. |
Post# 920620 , Reply# 5   2/10/2017 at 23:46 (2,602 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
My AEG Oko-Lavamat has an "energy savings" cycle for cottons/linens. Claims to do a full load at 140F but with reduced energy use.
Far as one can see it does so by using less than the already puny amounts of water the machine already uses, but cycle time is greatly increased to around three hours. Obviously less water taken for wash cycle the less there is to heat, so there you are then. Machine can get away with using such an even more puny amount of water for this ES cycle by running the recirulation pump constantly during the wash. This forces that small amount of water through the laundry. |
Post# 920631 , Reply# 6   2/11/2017 at 00:49 (2,602 days old) by tolivac (greenville nc)   |   | |
4 Hrs???? Take the things to the creek and beat them with a rock in less time!!!!These cycle times get longer and MORE ridiculous! |
Post# 920648 , Reply# 8   2/11/2017 at 03:20 (2,602 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Well yes that is true; but one does not always have twenty pounds of wash at a go.
Well suppose could wash *all* whites such as undergarments, bath and kitchen linen, t-shirts... the lot in one wash, but that isn't always wanted nor desired. Most H-axis washers are happiest at or near full load capacity for normal cottons/linens cycle. Smaller loads can and often do lead to issues with unbalanced loads and the stress that causes to a machine. Back to matter at hand; still am not buying this whole three or more hour cycles for washing machines and or automatic dishwashers. |
Post# 920653 , Reply# 9   2/11/2017 at 04:45 (2,602 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 920656 , Reply# 10   2/11/2017 at 05:04 (2,602 days old) by Logixx (Germany)   |   | |
Our consumer magazine had this diagram in their November 2015 issue. The left side says "140°F Cotton Normal, 142°F actual temp, half load, 1.09 kWh, 2:10 hrs. The right side is the 140°F Eco cycle: 93°F actual temp, half load, 0.5 kWh, 3:25 hrs. About half a kWh in energy savings doesn't sound like much - but if the advertising says "This cycles saves you more than 50% in energy costs... A++++++ energy efficiency", people will buy into it. As I said above, the survey showed that only about 20% of users actually select the Eco cycle, mostly because it takes them too long and they think that every cycle, not only the Eco one, is as efficient as the energy label says.
This AEG is rated at A+++ -70%, which translates into 100% more efficient than A, I think. At only 0.32 kWh for a 20 lbs. load on Eco, this cycle probably only "heats" to 77°F... and then you end up with 4 hour cycles.
Post# 920661 , Reply# 11   2/11/2017 at 05:28 (2,602 days old) by L86810 (Southend, UK)   |   | |
Post# 920677 , Reply# 12   2/11/2017 at 06:29 (2,602 days old) by tolivac (greenville nc)   |   | |
TIME is a MORE valueable resource to many over water or energy.Esp if they follow the safety rules and run the machine only while at home and awake.This nonsense has to go!!! |
Post# 920681 , Reply# 13   2/11/2017 at 06:39 (2,602 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Its all in the small print and screen Laundress, we thank our Euro testing labs for those wash times, you have the options of selecting options just over an hour which incidentally will still give us great eco energy efficient wash results than those resource guzzling behemouths in many basements. I are pleased you saw fit to test out our Euro style washers that give the best results in energy efficiency and eco resources AND you do get to see what a little warm heat can do with our heaters !!
My Asko has flexi options from 15 yrs ago, can do a 90d hot quick wash with 3 rinses and super 1600spin in just over an hour... |
Post# 920683 , Reply# 14   2/11/2017 at 06:45 (2,602 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Is nothing new in washing machine, Servis Domestic Appliances UK had a Multi-Fabric wash nearly 40yrs ago. consisting of a soak and tumble over many hrs (until you cancelled and selected rinse) this took advantage of the new generation of enzyme detergents such as Ariel which even now if you dumped all you clothes in a bucket or bathetub, added cool water and left steeping for a few hours would get similar results, again with the benefit of time to complete your wash...
Post# 920684 , Reply# 15   2/11/2017 at 06:52 (2,602 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 920685 , Reply# 16   2/11/2017 at 06:55 (2,602 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 920686 , Reply# 17   2/11/2017 at 07:00 (2,602 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 920688 , Reply# 19   2/11/2017 at 07:08 (2,602 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 920712 , Reply# 20   2/11/2017 at 09:43 (2,601 days old) by mrboilwash (Munich,Germany)   |   | |
I`m afraid as long as the EU energy label lacks information on fabric wear and rinsing efficiency the craze about endless cycle times and overloaded drums isn`t going to stop any time soon.
Our consumer magazine tells us there is no reproducible method to test fabric wear at the moment, but I *think* the EU has no desire to develop such a test as it would be counterproductive to the current energy savings at all costs policy. |
Post# 924504 , Reply# 22   3/2/2017 at 13:34 (2,582 days old) by l86810 (Southend, UK)   |   | |
Not sure if the link will work... but google translated an Electrolux article about a new Outdoor programme on the 9000 series models, complete with with this pic...
CLICK HERE TO GO TO l86810's LINK
Post# 924505 , Reply# 23   3/2/2017 at 13:40 (2,582 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
Still waiting for the manuals fir those big screen models; I'm really wanting to know how there user logic works... |
Post# 924506 , Reply# 24   3/2/2017 at 13:45 (2,582 days old) by l86810 (Southend, UK)   |   | |
There's also 4 new videos in English on the AEG youtube channel about 6000, 7000, 8000 and 9000 series washer dryers.
I've rarely seen Washer Dryers get a design update at the same time as the main washers and dryers, but the video seems to show the new design hidden in the shadows. Not sure if thats because they are alluding to new models coming out shortly (hopefully) or if they simply didn't want to show the older style models in the new videos they've been releasing so hid it from view?! However... although the older style Washer Dryers have converted over to the newer type model numbers on their websites they don't contain the Outdoor program which the advert talks about, so perhaps something new is on it's way? CLICK HERE TO GO TO l86810's LINK |
Post# 924509 , Reply# 25   3/2/2017 at 13:48 (2,582 days old) by l86810 (Southend, UK)   |   | |
Post# 924535 , Reply# 26   3/2/2017 at 17:05 (2,582 days old) by Hotpointwfwt02 (Manchester)   |   | |
Post# 927032 , Reply# 28   3/15/2017 at 16:18 (2,569 days old) by Ibaisaic (UK)   |   | |
Here's my brief review on the 8000 series washing machine. Tumble dryer review to follow. ?a |
Post# 941577 , Reply# 29   6/3/2017 at 12:10 (2,489 days old) by l86810 (Southend, UK)   |   | |
Its been uploaded the the AEG UK website, along with the user manual
L9FEA966C CLICK HERE TO GO TO l86810's LINK |
