Thread Number: 69595
/ Tag: Wringer Washers
Maytag E2L Pulley Shaft Seal |
Post# 925263 , Reply# 1   3/6/2017 at 09:12 (2,606 days old) by dermacie (my forever home (Glenshaw, PA))   |   | |
Post# 925468 , Reply# 2   3/7/2017 at 10:43 (2,605 days old) by Stan (Napa CA)   |   | |
Post# 925617 , Reply# 4   3/8/2017 at 01:32 (2,605 days old) by Stan (Napa CA)   |   | |
Post# 925796 , Reply# 5   3/9/2017 at 00:20 (2,604 days old) by Stan (Napa CA)   |   | |
Post# 925928 , Reply# 7   3/10/2017 at 01:20 (2,603 days old) by Stan (Napa CA)   |   | |
Post# 926014 , Reply# 9   3/10/2017 at 12:31 (2,602 days old) by Stan (Napa CA)   |   | |
Post# 926246 , Reply# 10   3/11/2017 at 15:10 (2,601 days old) by thesnail (PA)   |   | |
I'm probably not going to have time to work on it until next weekend. I will certainly take pictures of the repair. |
Post# 926269 , Reply# 11   3/11/2017 at 18:29 (2,601 days old) by Stan (Napa CA)   |   | |
Post# 926748 , Reply# 12   3/14/2017 at 08:46 (2,598 days old) by thesnail (PA)   |   | |
Phil said that the seal can be replaced with the power unit attached to the washer. |
Post# 927376 , Reply# 13   3/17/2017 at 00:07 (2,596 days old) by Stan (Napa CA)   |   | |
Post# 927703 , Reply# 15   3/18/2017 at 22:42 (2,594 days old) by thesnail (PA)   |   | |
1: Power Unit with pulley removed. 2: Clip, washer #1, spring washer, and washer #2 removed. 3: Old Seal removed. 4: Clip, washer #1, spring washer, washer #2, and old seal. 5: Old Seal. 6: New Seal. 7: New Seal installed. |
Post# 927731 , Reply# 16   3/19/2017 at 04:09 (2,594 days old) by Stan (Napa CA)   |   | |
Post# 927826 , Reply# 18   3/19/2017 at 22:16 (2,593 days old) by Stan (Napa CA)   |   | |
And I must have the same washer! Mines 1954.
Is u did the work from under? You didn't tip on its front ?
Post# 928025 , Reply# 20   3/20/2017 at 22:50 (2,592 days old) by Stan (Napa CA)   |   | |
Post# 928359 , Reply# 21   3/22/2017 at 20:41 (2,590 days old) by thesnail (PA)   |   | |
A coincidence! I always preferred the colors of the early '50s machines. The red wringer release, agitator, and agitator clutch handle go so well together. |
