Thread Number: 69654
/ Tag: Wringer Washers
Need help with my roller head |
Post# 925798 , Reply# 1   3/9/2017 at 00:32 (2,577 days old) by Stan (Napa CA)   |   | |
The head will drop back in position by pressing and holding down the pressure release bar (red or blue bar) and simultaneously turning the tension bar on top. Should drop back in and then you can retighten tension on the rollers again. Let me know if you've tried that. If you have, try again. If you have then your going to need a service manual that shows how to replace the spring. Think there's a service manual here somewhere.
HTH |
