Thread Number: 69720
Kenmore set |
Post# 926434   3/12/2017 at 19:50 (2,600 days old) by laundryboy (Orlando Florida & Moravia NY. )   |   | |
Hi everyone, does anyone know if this agitator could be swapped out for a Kenmore RotoSwirl ?
CLICK HERE TO GO TO laundryboy's LINK on Orlando Craigslist |
Post# 926437 , Reply# 1   3/12/2017 at 20:22 (2,600 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
The roto-swirl is intended for standard capacity machines and this is a newer style large capacity. Water will rise several inches higher on the RS than it does normally.
A proper cap is essential to protect the short centerpost and seals from flooding. The caps and seals used prior to 1978 are NOT good enough. Proper caps were available in both white and gold that come with new agitator studs and later style seals. They are part number 285155 and 285156. Gordon P.S. - regardless of what agitator is used, the auger in this machine appears to be broken. There are a number of them on eBay to fix this problem but if it is broken as it appears, it is probably sharp. |
Post# 926438 , Reply# 2   3/12/2017 at 20:24 (2,600 days old) by Yogitunes (New Jersey)   |   | |
Post# 926448 , Reply# 3   3/12/2017 at 21:03 (2,600 days old) by potatochips ( )   |   | |
Holy grail machine right there, someone get it! |
Post# 926468 , Reply# 4   3/12/2017 at 23:04 (2,600 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Post# 926497 , Reply# 5   3/13/2017 at 05:31 (2,599 days old) by washdaddy (Baltimore)   |   | |
when you refer to the auger in the machine being broken are you referring to the auger in the agitator? If yes, how can you tell that it's broken from looking at the picture? |
Post# 926512 , Reply# 6   3/13/2017 at 06:30 (2,599 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
Image number 9 shows a large portion of the auger missing leaving a pointed, probably sharp remnant.
Post# 926541 , Reply# 7   3/13/2017 at 09:59 (2,599 days old) by bajaespuma (Connecticut)   |   | |
Post# 926552 , Reply# 8   3/13/2017 at 10:56 (2,599 days old) by brucelucenta ()   |   | |
Looks more like a shadow to me. I don't think there is anything wrong with the agitator. |
Post# 926558 , Reply# 9   3/13/2017 at 11:26 (2,599 days old) by Yogitunes (New Jersey)   |   | |
Post# 926563 , Reply# 10   3/13/2017 at 11:58 (2,599 days old) by laundryboy (Orlando Florida & Moravia NY. )   |   | |
Post# 926577 , Reply# 11   3/13/2017 at 13:12 (2,599 days old) by laundryboy (Orlando Florida & Moravia NY. )   |   | |
Post# 926648 , Reply# 12   3/13/2017 at 19:51 (2,599 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
to you Christopher and to the machine! So glad it is going to a great home.
Interesting idea on the shadow, I can see what you all are saying. The S. Surgilator will work fine as long as it isn't a super-tall one pre-1973, which is relatively rare. Again, be sure to use a new style agitator stud and seal if you plan to use the machine in that configuration often. The new stud does a better job sealing the air under the agitator, especially when the cap is loose. Air leaks here can cause the bearings in the centerpost to get wet, water to foul the gearcase, etc. and will allow moisture to rust the shaft splines. The picture below I got from eBay. It has the best pic I could find of the seal and stud. This stud typically stays on the agitator when the cap is removed and maintains at least a lot of the seal. The older seals are loose as soon as the cap is loosened and air can leak quickly. The Kenmore caps I mentioned above use the same stud and seal, just different plastic caps.
Post# 926843 , Reply# 13   3/14/2017 at 16:14 (2,598 days old) by laundryboy (Orlando Florida & Moravia NY. )   |   | |
Hey everyone, Thank you for the help in deciding to buy this machine, I had it delivered today, now trying to decide which agitator to use, the Dual action was not broken, it was a shadow. Enjoy the pics
Chris |
