Thread Number: 69743
Dripping duet |
Post# 926663 , Reply# 1   3/13/2017 at 20:29 (2,593 days old) by mark_wpduet (Lexington KY)   |   | |
like that a LONG time ago and I discovered if you don't keep the under side of the glass wiped completely, just a wee bit of lint hair or cat hair on the glass where it seals to the rubber when you shut the door, will cause a small dripping leak as the washer runs. I've kept that area super clean after every load and never noticed another leak. I guess that any kind of small debris will cause it not to completely seal? At least this was the case with me. Mine was leaking exactly where you're pointing.
