Thread Number: 69788
/ Tag: Modern Dishwashers
Need help cleaning new stainless steel Maytag Dishwasher |
Post# 927244   3/16/2017 at 18:23 (2,595 days old) by maytaga806 (Howell, Michigan)   |   | |
We just picked up the new Maytag Jetclean DW! We haven't installed it, but Id like to clean some of these certain parts before we do. For one, why is the upper spray arm stained pure white? Also parts of the lower arm and tub are pretty white too, but the arm is stained. How can I clean that?
The racks on this thing are NICE!!! Im already very happy with how it looks! Just hope it works well! |
Post# 927246 , Reply# 1   3/16/2017 at 18:34 (2,595 days old) by Lorainfurniture (Cleveland )   |   | |
I would try soaking it in vinegar overnight. Run the dishwasher on a pots and pan cycle after. Just dump a gallon of vinegar in there and run it the next morning. |
Post# 927247 , Reply# 2   3/16/2017 at 18:39 (2,595 days old) by appnut (TX)   |   | |
Post# 927249 , Reply# 3   3/16/2017 at 18:40 (2,595 days old) by rp2813 (Sannazay)   |   | |
Post# 927250 , Reply# 4   3/16/2017 at 18:41 (2,595 days old) by appnut (TX)   |   | |
Post# 927252 , Reply# 5   3/16/2017 at 18:47 (2,595 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 927255 , Reply# 6   3/16/2017 at 18:48 (2,595 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
or you can hookup your dishwasher and clean it up with some finsih dishwasher cleaner by letting the dishwasher run a full cycle empty www.finishdishwashing.com/product... link to product in question
Post# 927259 , Reply# 7   3/16/2017 at 18:56 (2,595 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 927260 , Reply# 8   3/16/2017 at 18:56 (2,595 days old) by Yogitunes (New Jersey)   |   | |
nice machine, but not exactly in the best of shape at the moment.....
one of two things, either its detergent residue, or lime/scale from water conditions....CLR and LimeAway will take care of that just the same... but in any case.....this vid will get you started on removing the wash arm, and to gain access to the parts underneath, that your going to want to clean out of any debris, save yourself the trouble of doing it now..... those tall tubs are super nice, amazing the amount of dishes you can fit in there, top or bottom rack.... |
Post# 927300 , Reply# 9   3/16/2017 at 20:20 (2,595 days old) by Kb0nes (Burnsville, MN)   |   | |
Post# 927339 , Reply# 10   3/16/2017 at 22:02 (2,595 days old) by panthera (Rocky Mountains)   |   | |
It may get rid of nearly all of the white stuff. If that doesn't do the trick, but a lot is removed, try again. It's better to try citric acid on an unknown deposit first. Vinegar and several minerals form a very hard to remove deposit. If the citric acid does the job, great - if not - CLR will, BUT be sure you rub some vaseline over the plastic and metal around the vent holes. It can leave a film there or even attack the metal.
Post# 927343 , Reply# 12   3/16/2017 at 22:19 (2,595 days old) by Dustin92 (Jackson, MI)   |   | |
We have a 1997 Maytag Jetclean and I swear it would wash the chrome off a trailer hitch. Wonderful dishwasher, I hate to think of the day it breaks beyond repair. |
Post# 927394 , Reply# 13   3/17/2017 at 02:23 (2,595 days old) by mark_wpduet (Lexington KY)   |   | |
That wash arm looks exactly like my maytag. I love my machine. No problems yet almost 3 yrs old.
Anything with citric acid it in (sugar free lemonade drink mix powder) will eat that white stuff away, as with vinegar....but you have to make sure it starts in the main wash, or else it will get drained out during the first pre-wash |
Post# 927407 , Reply# 14   3/17/2017 at 05:15 (2,595 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 927408 , Reply# 15   3/17/2017 at 05:33 (2,595 days old) by appnut (TX)   |   | |
The first fill and "wash" is the prewash cycle. The next fill will be for main wash cycle. I suggest use pots & pans cycle with high temp wash. If you don't use the heaviest cycle (pots & pans), the sensor will detect it's empty of dishes and skip the drain between prewash and wash and go right into the main wash. The tag will tell you what model # this is and you can download the use & care manual from the Maytag web site. |
Post# 927464 , Reply# 17   3/17/2017 at 14:30 (2,594 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 927484 , Reply# 18   3/17/2017 at 17:28 (2,594 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 927514 , Reply# 19   3/17/2017 at 20:36 (2,594 days old) by mark_wpduet (Lexington KY)   |   | |
the lower wash arm does wiggle some.
It had been a few months since I had ran citric acid through mine, so after I finished a load last night and unloaded it - (I fill the main wash full of citric acid), then I put on the jetclean cycle which runs about 2 and a half hours. When done, the stainless, heating element, everything shined like new. Hopefully if your dishwasher is in working condition, you can get it looking new again inside.
Post# 927571 , Reply# 20   3/18/2017 at 08:10 (2,593 days old) by maytaga806 (Howell, Michigan)   |   | |
Post# 927732 , Reply# 21   3/19/2017 at 04:53 (2,593 days old) by askolover (South of Nash Vegas, TN)   |   | |
Mine too Dustin, it's just taking a vacation in MIL's basement while the new KUDI23 is working hard. My 97 Maytag still works great, just needs a little TLC after almost 20 years of trouble-free operation. I'm going to return it to it's portable state in a custom-built kitchen island to use for a spare. |
Post# 928336 , Reply# 22   3/22/2017 at 19:09 (2,589 days old) by mark_wpduet (Lexington KY)   |   | |
The other day, I used the Jetclean steam cycle completely empty with citric acid. When the machine is empty, it makes a much more noticeable water sloshing while the machine is running, right? So fast forward to my dishwasher being full last night and I needed to run it, and I always just hit start to start the cycle because the machine remembers the last cycle. The dishwasher was packed full of dishes.
Not paying attention and I had forgotten that I had the last cycle on Jetclean/Steam which I almost never use, but I end up using normal, hi temp, tough scrub, no dry. While the machine was running, it sounded like a LOT more vigorous water sloshing than I'm used to hearing and it was at this point I noticed it was on Jetclean/Steam, so I let it go. I just thought jetclean/steam had a longer wash cycle and perhaps more rinses, but I had no clue it had a more vigorous wash action or filled with more water per fill, but apparently it does. |
