Thread Number: 69874
/ Tag: Vintage Dishwashers
WTH? Kitchen Aid Superba |
Post# 928032   3/21/2017 at 06:14 (2,591 days old) by chachp (North Little Rock, AR)   |   | |
What are they washing in this thing? And what's left over in the soap dish? And look at the price for a machine in this condition? Is that really just from hard water? CLICK HERE TO GO TO chachp's LINK on eBay |
Post# 928035 , Reply# 1   3/21/2017 at 07:21 (2,591 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 928037 , Reply# 2   3/21/2017 at 07:27 (2,591 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
We often see DWs in this condition and worse, the first thing the users were doing wrong is they were pre-rinsing their dishes, How do I know this, because this DW was not working properly And the only way it was putting out dishes that were at all clean enough to use was because they were going in clean.
If you use a DW properly always putting visibly dirty dishes you will quickly know when something is not working with your machine.
My Aunt in Pennsylvania had a KDS-18 that was completely black inside, it turned out to have a bad wash-arm-support, bad inlet valve and clogged filter. It was so bad we trashed the DW and installed a new WP DW. |
Post# 928057 , Reply# 3   3/21/2017 at 09:56 (2,590 days old) by chachp (North Little Rock, AR)   |   | |
Post# 928062 , Reply# 4   3/21/2017 at 11:19 (2,590 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
To be clear. pre-rinsing or pre-washing DOES NOT CAUSE this condition!
To rephrase what John said, if you load your dishwasher without pre-rinse anything, you will quickly be able to tell if the dishwasher is not operating properly (dishes still dirty after the cycle is done). This one obviously has not been working correctly for a long time, with all that mold / mildew in it. Yuk!
Kevin
Post# 928079 , Reply# 5   3/21/2017 at 14:56 (2,590 days old) by Pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 928101 , Reply# 6   3/21/2017 at 17:33 (2,590 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 928115 , Reply# 7   3/21/2017 at 18:32 (2,590 days old) by Gyrafoam (Wytheville, VA)   |   | |
Must have quit working and they closed it up and walked away with water in it. Mold went wild. Clearly worse then repeated use of the Rinse & Mold Cycle. |
Post# 928169 , Reply# 8   3/22/2017 at 00:52 (2,590 days old) by tolivac (greenville nc)   |   | |
How can the machine be in "mint" condition when its a mold hole on the inside?Think the seller has been breathing too much of that black mold in there!You would have to PAY me to take that washer-may have to be buried in the hazmat dump! |
Post# 928262 , Reply# 9   3/22/2017 at 13:15 (2,589 days old) by Gyrafoam (Wytheville, VA)   |   | |
Spray it with Clorox Clean-Up and it will be gone in two minutes. |
Post# 930034 , Reply# 11   4/1/2017 at 05:24 (2,580 days old) by chachp (North Little Rock, AR)   |   | |
I've been watching this auction since it was originally posted at $125. They then re-listed for $200 and now has it listed for a Buy It Now at $245.
Is it just me who thinks this is nuts? Would somebody really buy this machine at that price and attempt to clean it up?
Maybe I should just mind my own business and hope the guy gets lucky but it never ceases to amaze me how some people think they have a goldmine on their hands because something is "Older" or "Vintage." CLICK HERE TO GO TO chachp's LINK on eBay |
Post# 930035 , Reply# 12   4/1/2017 at 06:05 (2,580 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 934863 , Reply# 13   4/26/2017 at 23:20 (2,554 days old) by funktionalart (Rison, AR)   |   | |
I'd save the steel panels and trim kit and set the rest on fire….I have one of those machines, and love it. But as was noted above, this level of mould accumulation is from someone closing the door on a damp and faulty machine and walking away for weeks/months on end. Bet there's a quart of swamp quality water sitting in the sump and drain hose...
Post# 934899 , Reply# 14   4/27/2017 at 06:38 (2,554 days old) by norgeway (mocksville n c )   |   | |
About a gallon of Clorox, and a couple gallons of boiling water and let it run...It will be clean as new in no time. |
Post# 935395 , Reply# 15   4/30/2017 at 00:52 (2,551 days old) by GusHerb (Chicago/NWI)   |   | |
Screw the Clorox make it a gallon of gasoline and a stick of dynamite!
I wouldn't want to see the home that thing came out of... |
Post# 935417 , Reply# 16   4/30/2017 at 03:06 (2,551 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 935431 , Reply# 17   4/30/2017 at 06:01 (2,551 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The black stains in this DW are not likley mold, they are more likley caused by conditions in the water supply coupled with mechaneal problems with the DW.
This DW could be saved if you wanted to save it, bleach would probably do little or nothing for staining if for example it is caused by magnesium in the water. In any case one should never consider putting a gallon of LCB in a DW, 1/4 cup would be about all you would ever need to sanitize and remove stains that LCB will remove, putting in a gallon will only destroy any rubber parts of this DW that may still be good. |
