Thread Number: 69887
Need a new washer/dryer combo |
Post# 928171 , Reply# 1   3/22/2017 at 01:26 (2,590 days old) by Stricklybojack (South Hams Devon UK)   |   | |
I am interested in the smaller 4.5 cu ft LG WM5000HVA. There is also the mammoth 5.8 LG Signature, model HW9500HKA. CLICK HERE TO GO TO Stricklybojack's LINK |
Post# 928239 , Reply# 4   3/22/2017 at 09:25 (2,590 days old) by ccny (New Milford, CT)   |   | |
Thanks. I mainly like the LG 9000 because it has excellent low-vibration ratings from Consumer Reports. |
Post# 928244 , Reply# 5   3/22/2017 at 10:07 (2,590 days old) by Lorainfurniture (Cleveland )   |   | |
All of the lg units are great at vibration control. |
Post# 928246 , Reply# 6   3/22/2017 at 10:35 (2,590 days old) by Whatsername (Denver, CO)   |   | |
Post# 928371 , Reply# 7   3/22/2017 at 21:51 (2,590 days old) by speedqueen (Metro-Detroit)   |   | |
I wouldn't look at any front loader.
I would say to look at one of Whirlpool's new belt-drive models or a new Speed Queen top-load washer w/ mechanical controls. In my opinion Consumer Reports is bird cage lining material and that they weigh all this Eco nonsense to much. While under test conditions a front loader may manage to out perform a top load model, in real life this isn't always the case. Front load models & HE top loaders rely on the fact that the regular cycle is so long that the enzymes in high end detergents will have time to basically soak out stains (sitting in a wash tub for 2 hours would accomplish the same thing). If you don't want to pay $10+ a bottle for detergent and/or have actual dirt on clothes you need something that actually "forces water through the clothes" with a proper vane type agitator as opposes to moving the clothes through the water(agi-peller/tumbling). Your Maytag likely has a sharp warn part on its agitator causing excess ware, in reality there are and have not been any models on the market that will cause excess clothing ware since Whirlpool discontinued their Direct-Drive models 5 years ago, and even they were not that bad if you did not overload. To address another point, unless your old 'Tags had a problem w/ shaking the floor, any machine would be fine for vibration except GE's top loaders(suspension too cheap) and Speed Queen's front loaders(suspension over-built and stiff). Whatever you choose, find the cheapest whirlpool dryer and get that if you are not concerned about the set matching. The internal design of the dryer has not changed since the 1960s and is one of the fastest dryers on the market. They are also very reliable and parts are very cheap and readily available. There is also no reason to get a dryer with tons of cycles considering the fact that there is virtually no difference between any of them and a standard "Automatic" cycle. On a final note, when something goes wrong on a front loader, further disassembly is usually required than w/ most top loaders thus increasing service call expenses. Here is a list of models of reasonable quality. ~Washers: Speed Queen - AWN432SP113TW04 (I personally own and have had no issues, It washes very well and feels sturdy) Whirlpool - WTW4616FW or WTW4816FW ~Dryers: Amana (Whirlpool made) - NGD4655EW Whirlpool - WGD4616FW |
Post# 928373 , Reply# 8   3/22/2017 at 21:54 (2,590 days old) by speedqueen (Metro-Detroit)   |   | |
Post# 928380 , Reply# 9   3/22/2017 at 22:11 (2,590 days old) by Stricklybojack (South Hams Devon UK)   |   | |
Richard, that is a compelling post. You are basically saying in general FLers wash better but TLers rinse better... I will add FLers usually spin better too. And adding a second or further rinse can fix the FL machines comparative rinse inadequacies. I don't know what you can do to a standard TL machine to get it to wash as well as a FL machine other than when a soak cycle is called for. |
Post# 928386 , Reply# 11   3/22/2017 at 23:18 (2,590 days old) by speedqueen (Metro-Detroit)   |   | |
Not only that, Robert, but I add that I think that with heavy dirt type soil(work jeans for example) the more aggressive action of a TL model forces the dirt out of the fibers.
Another thing to consider is that I know tons of people who use the short cycle on a FL because of how long the normal cycle is and thus don't get the solvent like action of modern, quality, enzyme detergents. Also you buy cheap detergent (Purex, Extra, Sun), the washing action alone of a FL cannot make up for the lack of enzymes like a TL model can with the more effective method of agitation. Look at Consumer reports from the 1950s, the FL models always scored at the bottom due to short cycle time and the traditional detergent w/o enzymes of the day. In other words if Joe Consumer uses the short cycle for everything and buys cheap detergent were back to the 1955 CR test of automatics. ***Also, if you didn't know the old CR articles are still available using web.archive.org for this site.(some have pages missing but it is better than nothing.) Here is a link. CLICK HERE TO GO TO speedqueen's LINK |
Post# 928413 , Reply# 13   3/23/2017 at 07:23 (2,589 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Far and away would be a Speed Queen Front Load Stack, these are easy to service when needed without un-stacking and because of there bolted together construction there is no vibration problem even if your floor is a little weak.
A SQ FLS will cost more initially but unless you do more than 10 loads a week and live there more than 25-50 years you will not have to replace this machine.
2nd best machine is the Whirlpool Top Load Stack for serviceability and longevity, major downside of the WP is much smaller washer capacity, much greater water use, and much harder on clothing.
Post# 928414 , Reply# 14   3/23/2017 at 07:39 (2,589 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Keep in mind when you stack two regular machines almost NOTHING can be accessed for service when they are stacked and installed, SO you need two men to remove the dryer just to diagnose most problems with the washer and many with the dryer as well.
When stacked you can not replace any parts on the dryer including the belt, the heater element, any thermal fuses, any of the electronic controls because you have to get to the back of the machine to even start disassembling the dryer.
And on the washer you have to get the dryer out of the closet and off the washer to do any repairs to the electronic controls, clean or replace the water pump.
On either the SQ or WP full Top Load stack all of these parts are easily accessible with out moving the machine even one inch.
And again keep in mind most separate machines when stacked are not bolted together very well so we constantly see problems relating to vibration on many installations.
Post# 928450 , Reply# 16   3/23/2017 at 11:32 (2,589 days old) by Stricklybojack (South Hams Devon UK)   |   | |
FL machines generally take much more space than TL machines...Speed Queen however is an exception. We have a SQ front loader that fits our smallish space but keeps breaking and SQ will NOT replace it even though it is under warranty. They continue replacing the same parts over and over in some sort of bizarre humiliating ritual. Others have experienced the same issue with the company. I digress. You don't have to go that route because Whirlpool makes a front load machine to fit laundry closets. Get an extended warranty and still pay only half of what a SQ set will cost. See the Whirlpool reviewed at bottom link. While you're there read their reviews of Speed Queen products too, linked here: laundry.reviewed.com/search/produ... spoiler alert, despite their high cost they rank nearer the bottom in performance, another something I wish I knew before buying one. CLICK HERE TO GO TO Stricklybojack's LINK
This post was last edited 03/23/2017 at 12:29 |
Post# 928543 , Reply# 17   3/23/2017 at 18:19 (2,589 days old) by Laundromat (Hilo, Hawaii)   |   | |
LG makes the best. Top or front loading. I've had both and great results. No repairs after restoration ( one had a clogged filter. The other one had a faulty door lock.)they've worked flawlessly for three years. I was able to increase the water level on the 8000 via the turn of a screw bandit has yet to beoverloaded. Good luck.
