Thread Number: 69912
Looking for a short basket drive |
Post# 928366 , Reply# 1   3/22/2017 at 21:31 (2,563 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
A short spin tube (13 11/32 inches vs. 18.5 of the previous) with the narrow pulley is almost unheard of. The part exists though, was used in I think one or two odd-ball KM models post 1977 and before 1982, including an 80 series 24-inch machine from 1980. Don't know if it was used in any WPs or not.
I saw one of these on eBay not long ago, but left it there because I figured I would never have a use for it. Let me dig up the part number to use....will come right back. Gordon |
Post# 928369 , Reply# 2   3/22/2017 at 21:43 (2,563 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 928372 , Reply# 3   3/22/2017 at 21:53 (2,563 days old) by Kenmoreguy64 (Charlotte, NC)   |   | |
The part number is 383931, but is no longer on eBay.
What is wrong with what you have? Spin tubes are easy to find, as are the bushings to restore the drive pulley, etc. Most often when I have used a whole drive assembly was when I wanted to save time and make a quick one for one swap, but that is an expensive way to go. If the restoration you're working on is missing the drive altogether, a 383929 / 285897 will supply all you need except the pulley, which can likely be had elsewhere and swapped. Gordon P.S. - just remembered you are working on a Canadian machine...that explains this unusual configuration. |
