Thread Number: 70879
Maytag A612 Damper pad inspection and replacement questions |
Post# 938748 , Reply# 2   5/15/2017 at 21:52 (2,536 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
These pads wear very little of nothing at all. They tend to come loose if either the glue fails that holds them to the steel base plate or if they get too dry they tear loose from the base plate.
Since you have it apart this far give them a good oiling with any lubricant that is good on polyester type plastic and put the machine back together and don't worry about them.
