Thread Number: 71149
/ Tag: Modern Dryers
Maytag Performa Dishwasher |
Post# 941809   6/4/2017 at 21:22 (2,488 days old) by Spacedogb (Lafayette, LA)   |   | |
Hey everyone, There is a Maytag Performa dishwasher in the house I am purchasing. Can someone give me some information on it? I have included a pic of a convertible model but mine is actually built in |
Post# 941810 , Reply# 1   6/4/2017 at 21:30 (2,488 days old) by Whatsername (Denver, CO)   |   | |
Post# 941811 , Reply# 2   6/4/2017 at 21:36 (2,488 days old) by Spacedogb (Lafayette, LA)   |   | |
I have never had a dishwasher with a heating delay so I'm kinda looking forward to trying it out. Sad it will soon be pulled out and sent to Habitat for Humanity |
Post# 941813 , Reply# 3   6/4/2017 at 21:57 (2,488 days old) by chetlaham (United States)   |   | |
Is this the machine with the drain solenoid?
Personally, anything with Performa on it is a sign to run, not walk, away from what ever holds that name. Performa was Maytag's half baked attempt at budget appliances that helped run the company into the ground. Maybe this machine is better, but if anything like the washers it is junk. |
Post# 941815 , Reply# 4   6/4/2017 at 22:08 (2,488 days old) by Spacedogb (Lafayette, LA)   |   | |
I'm not sure about the drain solenoid. I don't close on the house until the 15th but as soon as I do, I'll test it out and let you guys know. |
Post# 941837 , Reply# 5   6/5/2017 at 02:57 (2,488 days old) by askolover (South of Nash Vegas, TN)   |   | |
If it's set up anything like my Jetclean, the heating delay won't kick in unless the water is below a certain temperature. In the 20 years I've owned mine, the light has only come on maybe 3 times....twice when I had used lots of hot water and it wasn't fully reheated yet when it filled and once when the detergent foamed up a bunch for whatever reason. But my water heater is set somewhere around 150 so it had no reason to delay and heat the water. That looks like a Magic Chef dishwasher to me. |
Post# 941846 , Reply# 6   6/5/2017 at 05:01 (2,488 days old) by appnut (TX)   |   | |
This is like the equivalent of a Maytag MDB4000. No it doesn't have a drain solenoid. It may not have as good a filtration as its siblings. A slightly lower "hp" pump. Vinyl rather than nylon racks. But you still may be quite surprised it cleans fine. Pots & Pans with water heat SHOULD cause the heating delay to happen earlier in the main wash than normal wash & water heat on. |
Post# 943716 , Reply# 8   6/16/2017 at 07:38 (2,477 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 945614 , Reply# 9   6/27/2017 at 18:48 (2,466 days old) by Spacedogb (Lafayette, LA)   |   | |
Post# 945615 , Reply# 10   6/27/2017 at 18:56 (2,466 days old) by johnb300m (Chicago)   |   | |
Post# 945654 , Reply# 11   6/28/2017 at 02:46 (2,465 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 945715 , Reply# 12   6/28/2017 at 11:09 (2,465 days old) by johnb300m (Chicago)   |   | |
Post# 945748 , Reply# 13   6/28/2017 at 16:01 (2,465 days old) by chetlaham (United States)   |   | |
Post# 945999 , Reply# 14   6/30/2017 at 10:30 (2,463 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 946015 , Reply# 15   6/30/2017 at 12:37 (2,463 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 946025 , Reply# 16   6/30/2017 at 13:03 (2,463 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 946071 , Reply# 17   6/30/2017 at 16:57 (2,463 days old) by chetlaham (United States)   |   | |
A thermal hold. The timer motor will pause in certain parts of the cycle and not move until the water reaches a certain temperature say 140*F.
Combo is also spot on again. These were made to compete with other BOLs, but it was simply one of those things that helped ruin Maytag's name. And FWIW if Maytag had simply taken out the blower and heat delay they could have easily gotten down the cost to the point landlords and builders would have considered these over GE. But rather they designed it as though it was headed for the average working family but with a wash system headed apartments. |
Post# 946074 , Reply# 18   6/30/2017 at 17:35 (2,463 days old) by whirlykenmore78 (Prior Lake MN (GMT-0500 CDT.))   |   | |
Post# 946114 , Reply# 19   6/30/2017 at 20:35 (2,463 days old) by Spacedogb (Lafayette, LA)   |   | |
Its headed to craigslist as soon as I get a chance to pull it |
Post# 946141 , Reply# 20   6/30/2017 at 23:07 (2,462 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Someone will pick it up for a rental property, it's in reasonably good condition. My mother had a similar d/w in her new home, built in '03. Shortly after they ran it the first time, I pulled it out and insulated it all around. Helped some, but at the end of a peninsula in an open living room, dining, kitchen space, it did little good. Within 2 years, the racks were rusting and we pitched it.
Post# 946428 , Reply# 21   7/2/2017 at 20:49 (2,461 days old) by Spacedogb (Lafayette, LA)   |   | |
it has some light "rack rot" like I call it. Its only on the upper rack right front first 2 cross bars |
Post# 946455 , Reply# 22   7/3/2017 at 01:17 (2,460 days old) by askolover (South of Nash Vegas, TN)   |   | |
Post# 947734 , Reply# 24   7/11/2017 at 20:32 (2,452 days old) by johnb300m (Chicago)   |   | |
