Thread Number: 71246
Maytag Wringer Washer |
Post# 942978 , Reply# 2   6/11/2017 at 03:11 (2,510 days old) by Stan (Napa CA)   |   | |
Says to use Center seal grease 5616 (whatever that is) for most everthing with regards to wringer, and it's moving parts...Except it says to fill wringer head with 1lb of grease.. Says to use 56078 ?
Larry will probably stop by here and give you details on your questions for the power unit (transmission) and what kind of oil he used, can't remember off hand. 3 1/2 oz of power unit oil are supposed to be used in the cavity of the wringer post where the bevel gears mate. Hang on help is on the way |
Post# 943026 , Reply# 4   6/11/2017 at 14:27 (2,509 days old) by tarantulae (Colorado)   |   | |
As promised, here's some pictures. |
Post# 943116 , Reply# 5   6/11/2017 at 22:41 (2,509 days old) by Stan (Napa CA)   |   | |
You may be able to get most of what you need at the auto store or the auto section of WalMart, with maybe one exception
(the power unit) not sure if you can use 85 90 gear oil or not. The 3 1/2 oz mentioned in the service manual, may be the equivalent to the 1/4 lb soft grease mentioned below. Hope this helps Keep us posted |
Post# 943186 , Reply# 7   6/12/2017 at 13:48 (2,509 days old) by Stan (Napa CA)   |   | |
You found Larry and that thread! He will be a great source of info for you. (Good move with the bolts)
If you've read his entire thread.. It's long but worth the read, youl find that he ordered gaskets, I think you should too. If I remember correctly there was some adjustment he made to get everything to fit right and not leak during reassembly. I believe your right about the 3 1/2 oz of grease, and packing grease for the wringer head.. But double check with Larry or Geoff or recheck Larry's thread (info is in there) Yes yours will accommodate a pump. Youl most like find one one on eBay, and mostl likely it will be Phil from Ovid NY that has them, and offers them through eBay, as well as the correct gaskets, Think Larry added a pump as well when he restored his. Maytag pumps will make short work out of draining the water out. If you get one youl see what I mean. And if you have a sink or stand pipe for it to drain to, much easier. I'd say 55 would be the year of manufacture for yours.. If you post your serial number, We'l decode it and find the month and year. Take pics for us if you can, during your restore, we love pics.. Cuz we all want to be there to have our hands in it! Pics are the next best thing! I'm particularly interested in how you clean those gunked up parts. |
Post# 943248 , Reply# 9   6/13/2017 at 02:42 (2,508 days old) by Stan (Napa CA)   |   | |
Where the serial # is located on a model N. On a model E, it stamped just below the crown on th back of the machine. So with your N I'd stand behind the wringer post and look to the left near the top of the body.
Someone who has a N may come by? By looking at pic 3, I think I can see the pre drilled holes in the crossbar that will accommodate the pump assembly. |
Post# 943250 , Reply# 10   6/13/2017 at 03:07 (2,508 days old) by Stan (Napa CA)   |   | |
Post# 943281 , Reply# 11   6/13/2017 at 11:30 (2,508 days old) by tarantulae (Colorado)   |   | |
It has a lint screen (a little rusty, but what isn't on this one!) Its what made me think it had a pump originally. I found the serial number. Stamped in the back at the top of the skirt. 3562390 |
Post# 943283 , Reply# 12   6/13/2017 at 11:56 (2,508 days old) by ken (NYS)   |   | |
Check out the info listed in this thread for serial number date info.
www.automaticwasher.org/cgi-bin/T... Sorry...Looks like yours wouldn't be covered because its later than 1952. Didn't realize until after I posted. |
Post# 943296 , Reply# 14   6/13/2017 at 14:02 (2,508 days old) by stan (Napa CA)   |   | |
Post# 943303 , Reply# 16   6/13/2017 at 14:53 (2,507 days old) by stan (Napa CA)   |   | |
Post# 943311 , Reply# 17   6/13/2017 at 15:30 (2,507 days old) by tarantulae (Colorado)   |   | |
It won't come off. The bolts broke below the surface of the center plate but is still holding onto the PU. One of them has a bolt extractor broken in it too. I can't take the center plate off the PU. |
Post# 943383 , Reply# 18   6/13/2017 at 21:47 (2,507 days old) by Stan (Napa CA)   |   | |
The price was right for it! And it may come in handy for parts.
What model is the one your going to see (square tub, round tub) When you look at the one tomorrow.. There's a check list.. Make sure the agitator comes off and isn't stuck. Look for holes in the tub Look for think grease coming out of the breather hole in top of the right angle drive Look for oil running down one leg Make sure wringer turns and locks into position If possible plug in and check operation of agitator (that it starts and stops when knob is pulled in and out) If possible fill with water and check for leaks. If equipt with a pump, engage it to see. While running check to see if wringer rolls move in both directions I'm I forgetting anything, HTH and let us know |
Post# 943448 , Reply# 22   6/14/2017 at 14:46 (2,506 days old) by tarantulae (Colorado)   |   | |
It works. Looks like the pump wheel has flat spots from it rubbing on the drive wheel. Any idea where I can get replacements? Takes forever to gravity drain.
Post# 943518 , Reply# 25   6/14/2017 at 21:58 (2,506 days old) by Stan (Napa CA)   |   | |
Is for your washer, I'd grab it, as info, parts, ect may be a little harder to get than the Maytag.
I'm not fimiler with Thor Wringers but I would think it would handle the jeans, diapers ect as good as the Maytag would? My Maytag handles a thick terry bathrobe without hesitation. It might be that Maytags had the best wringers for that time? Someone will come by that knows Thors Keep us up to date. |
Post# 943519 , Reply# 26   6/14/2017 at 22:00 (2,506 days old) by Stan (Napa CA)   |   | |
Post# 943578 , Reply# 28   6/15/2017 at 10:39 (2,506 days old) by stan (Napa CA)   |   | |
Post# 943584 , Reply# 29   6/15/2017 at 11:32 (2,506 days old) by tarantulae (Colorado)   |   | |
I paid 125. Less than what I was looking at for fixing up the maytag. |
Post# 943607 , Reply# 30   6/15/2017 at 14:45 (2,505 days old) by stan (Napa CA)   |   | |
Post# 943768 , Reply# 31   6/16/2017 at 11:08 (2,505 days old) by bradross (New Westminster, BC., Canada)   |   | |
Duncan, if you lived closer, I'd sell you one of my wringer washers! I'm "overflowing" with 5 currently in my collection! And that's in an apartment! Can you imagine if I had a house - I'd start a wringer washer restoration business!
Best of success in rejuvenating the Thor. My mother and grandmother both had Thor machines from the late '30s. I've attached a couple of pics in case you'd like to see some older models. From what I know, they were very reliable machines. As you can see in the photos, the wringer assembly had two options for tension control - a screw or an automatic tension set/on-off lever (the type my mom had). |
