Thread Number: 71272
/ Tag: Wringer Washers
need a model number for wringer washer |
Post# 943319 , Reply# 1   6/13/2017 at 16:43 (2,502 days old) by ken (NYS)   |   | |
Without a picture its kind of hard to tell. But the number you posted corresponds to Model 15 & 16 produced from 1931 to 1939. Check out this site:
www.maytagclub.com/... "Maytag Evolution" link on left will give you pictures of the different models produced. Click on "Restoration Info" link on left and then third link in the list "Wringer washer model identification information with serial number" for a list of models and serial numbers. |
Post# 943325 , Reply# 2   6/13/2017 at 17:11 (2,502 days old) by hippiedoll ( arizona )   |   | |
A description might help if you don't have no pictures right now.
Is it a square tub or round tub? Is it all white? Or is the bottom white and the top of the tub silver/aluminum? Does the washers lid open to the side & connected to the top of the washtub? Or can you take the lid completely off the washer? Some of these answer might help identify the model without any pictures. :o) |
Post# 943384 , Reply# 3   6/13/2017 at 21:52 (2,502 days old) by Stan (Napa CA)   |   | |
Post# 943523 , Reply# 5   6/14/2017 at 22:27 (2,501 days old) by Stan (Napa CA)   |   | |
a 1955. I think that Turquoise release bar and knob came out in 1966. Before that they were red.
Its a model N but I still can't decode the year from that number to determine exact year. The D and the K are throwing me off. There's one service manual for model E J and N. So you won't have a problem getting one. There one here on the forum that you can download. I can't tell from the pics if yours is a pump model or gravity drain. Is the machine fuctining? How the inside tub? Needs some wet sanding and a repaint, but if it's agitating, wringing, draining., then your in good shape! Let us know |
Post# 943524 , Reply# 6   6/14/2017 at 22:28 (2,501 days old) by Stan (Napa CA)   |   | |
Post# 943537 , Reply# 8   6/15/2017 at 01:06 (2,500 days old) by Stan (Napa CA)   |   | |
I like to see those two pieces.
Are you able to take off the agitator? It's suppose to be removed when not in use so you can clean under it. If it was a pump model, its suppose to have a screen under the agitator that is removable for cleaning. (Screen also protects the pump from objects that could cause damage to the pump) Your machine has pre drill holes in the cross bars underneath for a pump to be added if the customer wanted to add one. It's not 1940... It's may look like it is because when Maytag came out with their N models, they never changed their design. A 1940 would have had a aluminum agitator, the release bar, and pull knob would have been red. Not sure when Matag changed to a red agitator, but would have been sometime after WW2. About 1954 they changed the agitator to black, then about 1966 changed the agitator, release bar, and pull knob to turquoise. Tubs, motors, transmission, gears, pumps, belt, ect all remained the same. Let us know how you make out. There are lots of parts out there for these machines because they didn't change. And they contuied manufacturing their model E til 1983. Someone who know ps these machine better may come by, and know how to decode, and give you a month and year of manufacture, but I know for sure it's not a 1940 |
Post# 943558 , Reply# 9   6/15/2017 at 08:39 (2,500 days old) by ken (NYS)   |   | |
Take a look at the last post in this thread which discusses serial numbers and date codes on later models. Judging that DK is not in the list it looks like yours is 1966 or later. The person who told you 1967 when you called Maytag is probably correct.
CLICK HERE TO GO TO ken's LINK This post was last edited 06/15/2017 at 09:00 |
Post# 943600 , Reply# 10   6/15/2017 at 14:08 (2,500 days old) by hippiedoll ( arizona )   |   | |
Brand: Maytag
Type: Clothes Washer Country: USA Model: N2L Serial: 67977DKAccording to the serial number this product may have been manufactured August of 1962 I hope this information helps you. Even though the turquoise color of the agitator, release bar, and pull knob don't seem to match up with that date information. |
Post# 943830 , Reply# 12   6/16/2017 at 14:55 (2,499 days old) by hippiedoll ( arizona )   |   | |
Post# 943878 , Reply# 13   6/16/2017 at 19:51 (2,499 days old) by stan (Napa CA)   |   | |
That's a very common part that can break. Usually because someone man handled the wringer while its locked. It a easy fix.. I replaced mine.. You'l probably find one on eBay or contact Phil in N.Y
I hung on to my broken one in case it could be welded back together. Your doing well so far! You should be up in running after replacement of that part. Let us know |
Post# 943931 , Reply# 14   6/17/2017 at 03:16 (2,498 days old) by jbj1162 (Hayward California)   |   | |
do you have contact info for Phil in NY Stan ? |
Post# 943932 , Reply# 15   6/17/2017 at 03:36 (2,498 days old) by Stan (Napa CA)   |   | |
Post# 944361 , Reply# 17   6/20/2017 at 09:59 (2,495 days old) by Stan (Napa CA)   |   | |
for the pump where made during manufacturing. This dose not mean it was originally sold with a pump. Just means that it was made to acomadate one. I'll look around for parts other than eBay that may work for you... Davies Repair might have the index slide, but the pump will take longer to locate with out eBay.
Post# 944474 , Reply# 18   6/21/2017 at 10:58 (2,494 days old) by bradross (New Westminster, BC., Canada)   |   | |
This seller is/was a member here - Jim Barnard (club I.D. - "wringer"). It did not sell, so perhaps he will re-list it if asked.
CLICK HERE TO GO TO bradross's LINK on eBay
Post# 946217 , Reply# 19   7/1/2017 at 12:31 (2,484 days old) by jbj1162 (Hayward California)   |   | |
stan do you have contact info for Davies Repair I'm trying to find that index slide thx 4 looking |
Post# 947922 , Reply# 21   7/13/2017 at 00:00 (2,472 days old) by Stan (Napa CA)   |   | |
Post# 948032 , Reply# 22   7/13/2017 at 10:11 (2,472 days old) by bradross (New Westminster, BC., Canada)   |   | |
Hi Jeffrey,
Here's a copy from my manual of serial number ... your machine was manufactured in May, 1967. Re. greasing ... further to Stan's comment, if there's no obvious sign of displacement of gear box lubricant down the wringer leg (the usual location), and there's no sound of "stress" when it's running, there should be no need to be concerned. Have a look underneath at the horizontal drive for the wringer to see if grease has leaked out of the small port that's located on the top of the tube. The ball bearings at each end of the upper wringer roll should be oiled with 3-in-1 every so often, and also the casters, to keep them freely rolling. And as Stan mentioned, the agitator post should be coated lightly with Vaseline to enable easy removal of the agitator. That's it!
Post# 948034 , Reply# 23   7/13/2017 at 10:14 (2,472 days old) by bradross (New Westminster, BC., Canada)   |   | |
Sorry that last attachment wasn't very good...here's a better copy.
