Thread Number: 7145
Pump for Kitchenaid KDC-18 Dishwasher |
Post# 140921 , Reply# 2   7/8/2006 at 19:11 (6,473 days old) by blackstone (Springfield, Massachusetts)   |   | |
In addition to the suggestions in the above posting, I might also suggest to listen to hear if you actually hear any water during the fill cycle. You should be able to hear it, and feel the water pipe getting hot. With the bottom front panel off, you can manually operate the float switch and the drain selenoid. Use an ohmmeter to check for power being applied to these. Coincidentially, I currently have brand new front panels for this model dishwasher up on eBay, if you need replacements. |
