Thread Number: 71726  /  Tag: Classified Ad Finds
RR-4D Vintage Amana Radarange Microwave Oven - $120 (Westchester)
Post# 949049   7/19/2017 at 23:48 (2,462 days old) by ovrphil (N.Atlanta / Georgia )
ovrphil's profile picture
CLICK HERE TO GO TO ovrphil's LINK on Chicago Craigslist
Post# 949070 , Reply# 1   7/20/2017 at 06:35 (2,462 days old) by turquoisedude (.)
turquoisedude's profile picture
Decent price....  These work amazingly well - I was happily surprised at how well the one I put into the kitchen in St-Lib heats so evenly.
Post# 949106 , Reply# 2   7/20/2017 at 11:49 (2,462 days old) by realvanman (Southern California)
When were these made?
I am going to be outfitting a 1955 bus for RV use, and want to keep everything as period correct as possible. I always imagined that one of these would be close enough for a MW oven. :)
Post# 949107 , Reply# 3   7/20/2017 at 12:08 (2,462 days old) by turquoisedude (.)
1971-ish...  I wanted a 60s themed kitchen in St-Lib, but this was a happy compromise for a microwave!
Post# 949140 , Reply# 4   7/20/2017 at 17:06 (2,462 days old) by cadman (Cedar Falls, IA)
cadman's profile picture
For a '55 bus this would be a good compromise. These came out in '74 and were the first Radaranges with defrost. BUT, I suspect the rust stains in the one photo are between the metal grill and outer plastic and it's going to take some work to repair that. Not insurmountable, but you'll have to pull the outer case and side panel, remove the door springs to take pressure off the door assembly, and then carefully disassemble the door, up to and including removing some nuts on plastic studs that were never meant to be removed. For that reason alone I wouldn't give more than $40.
Post# 949424 , Reply# 5   7/22/2017 at 10:15 (2,460 days old) by ovrphil (N.Atlanta / Georgia )
Patience is just the beginning element needed...
Add some muscle, cursing, and more patience if you decide to take on a door on an Amana RR. Phew, been there, done that. It's not that it isn't possible, but as Cory explained, it doesn't necessarily get easier.
It looks nice, otherwise.
