Thread Number: 71797
Dirty streaks on some bed sheets |
Post# 949790 , Reply# 1   7/24/2017 at 08:53 (2,461 days old) by brucelucenta ()   |   | |
You might check your dryer too. Sounds more like a dryer problem than washer. If the bearings were going bad, you would probably hear it. |
Post# 949797 , Reply# 2   7/24/2017 at 09:48 (2,461 days old) by ea56 (Cotati, Calif.)   |   | |
Sounds like streaks that can sometimes be left by dryer fabric softener sheets. Did you use a different brand or were they a new box that you hadn't used before? Also, sometimes if the heat is too high in the dryer these fab softener sheets will leave greasy streaks. You can get rid of them by rubbing regualr old bar soap on them and re washing the sheets in hot water with detergent.
Eddie |
Post# 949819 , Reply# 4   7/24/2017 at 12:17 (2,461 days old) by henene4 (Heidenheim a.d. Brenz (Germany))   |   | |
If you hear the washer signal, you would hear it spin with a bearing failure for sure. |
Post# 949825 , Reply# 5   7/24/2017 at 13:18 (2,461 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
